amien
Helper V
Helper V
Spark SQL data frame using in another Spark SQL dataframe
I have this df
df_100 = spark.sql("""SELECT * FROM SOURCE""")
But now i want to use this df_100 as source for another df
df_200 = spark.sql("select KEYFIELD from df_100")
How can i make this work? I get an error that the table doesn't exist.
If i use this it works:
df_100.createOrReplaceTempView("df_100")
it is possible to remove the first step (createOrReplaceTempView) or is there a better way to do this?
lbendlin
df_200 = df_100.select("KEYFIELD")
lbendlin
July Power BI Update Carousel
