sourav94
M Code working in Power Query but not in Power BI desktop (For Autodesk Forge Custom connector)
v-lionel-msft
Hi @sourav94 ,
I can't access these two image files, but I tested your custom connector, and the following step works fine.
Please use Onedrive For Business to share your picture files.
Or Please refer to the link.
Connector extensibility in Power BI
Best regards,
Lionel Chen
Hi Thanks for the prompt response.The addin starts fine but gets stuck at the authorisation page after granting permission.(Image attached),no authorisation token is generated. When running the same addin in debug mode in visual studio it functions properly and the authorisation token is generated. You can use the following url t o test it.-
https://developer.api.autodesk.com/project/v1/hubs
