Showing results forย
Search instead forย
Did you mean:ย
perezco
Advocate III
Advocate III
"power bi" inactive relation for two fact tables same column (order_id)
under table1 ('Fact - order') I tried create the below column
Column order = CALCULATETABLE( LASTNONBLANK('Fact - order'[order_wid],'Fact - order'[order_wid]),USERELATIONSHIP('Fact - order'[order_wid],'Fact - order Parts'[order_wid]))
two fact order tables (relationship is inactive but 1 --->> *, I need   1 <<---*    because my intention is that any part is been choosen in table two will brings the orders from table 1 and their commodity, is this possible?
table one                                                             table two
order_ID - commodities   1<<---need be----*   order_id -parts# - partsQties
(unique values)                                                    (many)
----extra
the commodity brings somehing like this
Hard Drive-XXW34 :(2)
Hi @Cperota ,thanks for the quick reply.
Hi @perezco ,
Regarding your question, I made an attempt.
The Table data is shown below:
Please follow these steps:
1.Modify the filter passing direction
2.Use the following DAX expression to create a measure
Measure = CALCULATE(SELECTEDVALUE('Fact - order'[Product]),USERELATIONSHIP('Fact - order Parts'[order_wid],'Fact - order'[order_wid]))
3.Final output
Wenbin Zhou
Hi @perezco ,
3.Final output
Wenbin Zhou
Cperota
did you try lookup function ?>> The lookup   function is a good option when you need a single column.
https://www.sqlbi.com/articles/lookup-multiple-values-in-dax/
thanks, @Cperota
The table 2  'Fact - order Parts' is the one that need to get the column string values 'commodity description' from table 1 'Fact - order'.
To avoid inaccurate calculations,
I am trying to  do it without USERELATIONSHIP function active /not active stage.
Column (inactive) =
ADDCOLUMNS (
'Fact - order Parts',
"commodity_desc",
VAR order_wid_ =
'Fact - order Parts'[order_wid]  //----->my issue here - I have mutiple wo_id
LOOKUPVALUE (
'Fact - order'[commodity_desc],
'Fact - order'[order_wid], 'Fact - order Parts'[order_wid],
'Fact - order'[order_wid], order_wid_
"TREATAS connection",
VAR A_treatas =
TREATAS( VALUES('Fact - order'[order_wid]), 'Fact - order Parts'[order_wid])
A_treatas
note: I am having proble to answer @Anonymous . I dont understand my message keep be deleted it.
