Hello i need some help with a running total measure. i have this running total measure:
@Krijgersss
You can follow this pattern to achieve running total https://www.sqlbi.com/articles/computing-running-totals-in-dax/
Also, if you are using the latest version of Power BI desktop then you can use visual calculations to avoid complex DAX
https://learn.microsoft.com/en-us/power-bi/transform-model/desktop-visual-calculations-overview
If the post helps please give a thumbs up
If it solves your issue, please accept it as the solution to help the other members find it more quickly.
Tharun
| 8 | |
| 7 | |
| 6 | |
| 5 | |
| 5 |
| 24 | |
| 11 | |
| 9 | |
| 9 | |
| 8 |
