Krijgersss
Helper II
Helper II
need help with a running total measure
Hello i need some help with a running total measure. i have this running total measure:
Voorlopig totaal van revenue in month =
CALCULATE(
    SUM('newfysic view_store_performance_per_month'[revenue]),
    FILTER(
        CALCULATETABLE(
            SUMMARIZE(
                'newfysic dimension_date',
                'newfysic dimension_date'[period],
                'newfysic dimension_date'[month]
            ALLSELECTED('newfysic dimension_date')
        ISONORAFTER(
            'newfysic dimension_date'[period], MAX('newfysic dimension_date'[period]), DESC,
            'newfysic dimension_date'[month], MAX('newfysic dimension_date'[month]), DESC
but this measure is cumulative i  just want a running total measure that isnt cumulative does somebody now how i can maken that or what i need to change
many thanks
tharunkumarRTK
@Krijgersss
You can follow this pattern to achieve running total https://www.sqlbi.com/articles/computing-running-totals-in-dax/
Also, if you are using the latest version of Power BI desktop then you can use visual calculations to avoid complex DAX
 https://learn.microsoft.com/en-us/power-bi/transform-model/desktop-visual-calculations-overview
If the post helps please give a thumbs up
If it solves your issue, please accept it as the solution to help the other members find it more quickly.
Tharun
