raw date is from A~D
I want to get final unshipping quantity and Cumulative quantity (L & M column)
but I can't find perfect solution to solve this problem
K5 = C2+C3(=35000) - C5( first time instock group by order no )
K7 = K5-C7( second time instock group by order no )
K6 = K7-C6( third time instock group by order no )
K4= K6-(C4+C8) ( foruth time instock group by order no and it has 2 times "instock" in one day )
L4 = total scheduled_qty - total instock_qty (35000-22281)
| order_no | date | QTY | type |
| A24040025 | 2024/5/13 | 30878 | schedule_ship_date |
| A24040025 | 2024/12/31 | 4122 | schedule_ship_date |
| A24040025 | 2024/6/19 | 1922 | instock_date |
| A24040025 | 2024/5/3 | 4196 | instock_date |
| A24040025 | 2024/5/20 | 2335 | instock_date |
| A24040025 | 2024/5/15 | 15 | instock_date |
| A24040025 | 2024/6/19 | 13813 | instock_date |
| A24070109 | 2024/8/21 | 4000 | schedule_ship_date |
| A24060046 | 2024/7/12 | 1323 | schedule_ship_date |
| A24060046 | 2024/7/30 | 1 | instock_date |
| A24060046 | 2024/7/29 | 1 | instock_date |
| A24060046 | 2024/7/30 | 212 | instock_date |
| A24060046 | 2024/7/19 | 1098 | instock_date |
Hi, @iamjoy
Already have a preliminary understanding of what you need, but you didn't give any indication of how to determine the qty value corresponding to a type of instock_qty. For example, how to get the value 15735. One more thing, why the qty of A240600046 and A24070041 are marked in green, they have different order_no, which is different from the other calculation logic.
Yang
Community Support Team
Hi, @iamjoy
You can try following dax to achieve your need.
DAX:
sumQTY By OrderNo and type =
CALCULATE(
SUM('Table'[QTY]),
FILTER(
'Table',
'Table'[type] = EARLIER('Table'[type])
&& 'Table'[order_no] = EARLIER('Table'[order_no])
Result 1 =
VAR CurrentIndex = 'Table'[Index]
VAR NextIndex = CurrentIndex + 1
VAR CurrentOrderNo = 'Table'[order_no]
VAR CurrentDate = 'Table'[date]
VAR NextType =
MAX ( 'Table'[type] ),
FILTER ( 'Table', 'Table'[Index] = NextIndex )
VAR PreviousFinalUnshippedQty =
MAX ( 'Table'[sumQTY By OrderNo and type] ),
VAR _result1 =
IF (
COUNTROWS(
FILTER(
'Table',
'Table'[order_no] = CurrentOrderNo &&
'Table'[date] = CurrentDate
) > 1,
DIVIDE(SUM('Table'[QTY]),COUNTROWS(
FILTER(
'Table',
FILTER(
'Table',
BLANK()
VAR _result2 =
IF (
CurrentOrderNo
= CALCULATE (
MAX ( 'Table'[order_no] ),
&& 'Table'[type] <> NextType,
'Table'[sumQTY By OrderNo and type] - PreviousFinalUnshippedQty,
_result1
_result2
Result 2 =
IF(
'Table'[Result 1] = BLANK() ,
'Table'[QTY]
final_unshipped_qty =
VAR _qty = 'Table'[Result 2] + 'Table'[Result 1]
VAR _index = 'Table'[Index]
IF(_index = 1,BLANK(),_qty)
New type =
VAR _type =
SWITCH(
'Table'[type],
"schedule_ship_date","final_unshipped_qty",
"instock_date","instock_qty"
IF(
'Table'[final_unshipped_qty] <> 0,
_type
Yang
If there is any post helps, then please consider Accept it as the solution to help the other members find it more quickly.
If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
How to get your questions answered quickly -- How to provide sample data in the Power BI Forum
Hi, @iamjoy
You can try the following dax to achieve your need.
DAX:
VAR PreviousIndex = CurrentIndex - 1
VAR PreviousType =
FILTER ( 'Table', 'Table'[Index] = PreviousIndex )
VAR _result1 =
IF (
CurrentOrderNo
= CALCULATE (
&& 'Table'[type] <> PreviousType,
PreviousFinalUnshippedQty - 'Table'[sumQTY By OrderNo and type],
BLANK ()
VAR _orderCount =
COUNT ( 'Table'[order_no] ),
FILTER ( 'Table', 'Table'[order_no] = CurrentOrderNo )
VAR _result2 =
IF ( _orderCount = 1, CALCULATE ( MAX ( 'Table'[QTY] ) ) )
_result1 + _result2
Yang
thank you so much
but I need 'final_unshipped_qty' and 'date' column like this
Hi, @iamjoy
Do you mean to regenerate a table with only the dates marked yellow and the corresponding final_unshipped_qty values?
Yang
result BI table like this
so I think what i need from raw data to A21~D21 table is right?
Hi, @iamjoy
Sorry, still can't see what you need, does the table you want refer to all the data in rows 21-34 or rows 21, 22, 27, 28, 32.
Yang
sorry..result BI table can't be translated to English
does the table you want refer to all the data in rows 21-34 or rows 21, 22, 27, 28, 32.>> no, it's from all this table
and I think this way is more clearly?
result table is from A20:D33 and A20:D33 is from A1:D17 (raw data)
I can't find the solution to turn raw data to A20:D33..
Hi, @iamjoy
Yang
Hi, @iamjoy
DAX:
CALCULATE(
SUM('Table'[QTY]),
FILTER(
'Table',
Result 1 =
VAR NextType =
VAR _result1 =
IF (
COUNTROWS(
FILTER(
'Table',
) > 1,
FILTER(
'Table',
FILTER(
'Table',
BLANK()
VAR _result2 =
IF (
CurrentOrderNo
= CALCULATE (
_result1
_result2
Result 2 =
IF(
'Table'[QTY]
New type =
VAR _type =
SWITCH(
'Table'[type],
IF(
_type
Yang
thank you for your reply
15735 is from C4+C8 (1922+13813, group by order_no and date, it's shipped on 6/19 )
and total instock qty group by order no , for example , A24040025 is 22281 , and all schedule ship qty is 30878+4122=35000
so 35000-22281=12719 (as final_unshipped_qty, and date need to use max schedule_ship_date, so it belongs to December)
why the qty of A240600046 and A24070041 are marked in green, they have different order_no, which is different from the other calculation logic. >>>> It's all instocked in July (2182=213+1+1098+2+868), the result BI table will show instocked_qty and final_unshipped_qty by year/month
Similarly, we can get total instocked_qty in June is 15735, in May is 6546 (c23+c24+c25) and we don't have instocked_qty in Auguest.
| 20 | |
| 10 | |
| 9 | |
| 4 |
| 33 | |
| 31 | |
| 19 | |
| 12 | |
| 11 |
