iamjoy's avatar
iamjoy
2 years ago
dax problem: subtract multiple values in same column based on DATE and filter and get final values
raw date is from A~D
I want to get final unshipping quantity and Cumulative quantity (L & M column)
but I can't find perfect solution to solve this problem
K5 = C2+C3(=35000) - C5( first time instock group by order no )
K7 = K5-C7( second time instock group by order no )
K6 = K7-C6( third time instock group by order no )
K4= K6-(C4+C8) ( foruth time instock group by order no and it has 2 times  "instock" in one day )
L4 = total scheduled_qty - total instock_qty (35000-22281)
order_nodateQTYtype
A240400252024/5/1330878schedule_ship_date
A240400252024/12/314122schedule_ship_date
A240400252024/6/191922instock_date
A240400252024/5/34196instock_date
A240400252024/5/202335instock_date
A240400252024/5/1515instock_date
A240400252024/6/1913813instock_date
A240701092024/8/214000schedule_ship_date
A240600462024/7/121323schedule_ship_date
A240600462024/7/301instock_date
A240600462024/7/291instock_date
A240600462024/7/30212instock_date
A240600462024/7/191098instock_date
    2 years ago
    Hi, iamjoy
    Already have a preliminary understanding of what you need, but you didn't give any indication of how to determine the qty value corresponding to a type of instock_qty. For example, how to get the value 15735. One more thing, why the qty of A240600046 and A24070041 are marked in green, they have different order_no, which is different from the other calculation logic.
    Yang
    Community Support Team
    2 years ago
    Hi, iamjoy
    You can try following dax to achieve your need.
    DAX:
    sumQTY By OrderNo and type =
    CALCULATE(
        SUM('Table'[QTY]),
        FILTER(
            'Table',
            'Table'[type] = EARLIER('Table'[type])
            && 'Table'[order_no] = EARLIER('Table'[order_no])
    Result 1 =
    VAR CurrentIndex = 'Table'[Index]
    VAR NextIndex = CurrentIndex + 1
    VAR CurrentOrderNo = 'Table'[order_no]
    VAR CurrentDate = 'Table'[date]
    VAR NextType =
            MAX ( 'Table'[type] ),
            FILTER ( 'Table', 'Table'[Index] = NextIndex )
    VAR PreviousFinalUnshippedQty =
            MAX ( 'Table'[sumQTY By OrderNo and type] ),
    VAR _result1 =
    IF (
        COUNTROWS(
            FILTER(
                'Table',
                'Table'[order_no] = CurrentOrderNo &&
                'Table'[date] = CurrentDate
        ) > 1,
            DIVIDE(SUM('Table'[QTY]),COUNTROWS(
            FILTER(
                'Table',
            FILTER(
                'Table',
        BLANK()
    VAR _result2 =
        IF (
            CurrentOrderNo
                = CALCULATE (
                    MAX ( 'Table'[order_no] ),
                && 'Table'[type] <> NextType,
            'Table'[sumQTY By OrderNo and type] - PreviousFinalUnshippedQty,
            _result1
        _result2
    Result 2 =
    IF(
        'Table'[Result 1] = BLANK() ,
        'Table'[QTY]
    final_unshipped_qty =
    VAR _qty = 'Table'[Result 2] + 'Table'[Result 1]
    VAR _index = 'Table'[Index]
    IF(_index = 1,BLANK(),_qty)
    New type =
    VAR _type =
        SWITCH(
            'Table'[type],
            "schedule_ship_date","final_unshipped_qty",
            "instock_date","instock_qty"
    IF(
        'Table'[final_unshipped_qty] <> 0,
        _type
    Yang
    If there is any post helps, then please consider Accept it as the solution to help the other members find it more quickly.
    If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
    How to get your questions answered quickly --  How to provide sample data in the Power BI Forum
    Hi, iamjoy
    You can try the following dax to achieve your need.
    DAX:
    VAR PreviousIndex = CurrentIndex - 1
    VAR PreviousType =
            FILTER ( 'Table', 'Table'[Index] = PreviousIndex )
    VAR _result1 =
        IF (
            CurrentOrderNo
                = CALCULATE (
                && 'Table'[type] <> PreviousType,
            PreviousFinalUnshippedQty - 'Table'[sumQTY By OrderNo and type],
            BLANK ()
    VAR _orderCount =
            COUNT ( 'Table'[order_no] ),
            FILTER ( 'Table', 'Table'[order_no] = CurrentOrderNo )
    VAR _result2 =
        IF ( _orderCount = 1, CALCULATE ( MAX ( 'Table'[QTY] ) ) )
        _result1 + _result2
    Yang
    • iamjoy's avatar
      iamjoy
      thank you so much
      but I need 'final_unshipped_qty'  and 'date' column like this
        Hi, iamjoy
        Do you mean to regenerate a table with only the dates marked yellow and the corresponding final_unshipped_qty values?
        Yang
