I´ve got a problem in power bi that i´ve been unable to find an answer to or solve yet.
So what we have is one excel file and a table from a SQL server with 1 table in each that I have imported in Power BI
The first table have a column with a unique ID and a column with unique date and time.
each rows represent a product with manufacturing data for that specific product.
Table looks like this:
Product ID | Completed time
1 2022-08-31 06:00
2 2022-08-31 06:02
3 2022-08-31 06:05
and so on
In the Second table we have a list of when a specific parameter is changed
in this table we have a column for date and time and a column with the changed value.
looking like this:
What i want to do is to add a column to the first table and put the changed value from the Second table and put that for each unique product that is produced after the changed parameter.
the table should look something like this like this:
Product ID | Completed time | parameter from second table
1 2022-08-31 06:00 1,85
2 2022-08-31 06:02 1,85
3 2022-08-31 06:05 1,85
In Excel I would use the Xlookup function to get this to work: =XLOOKUP(I2;$A$2:$A$30;$B$2:$B$30;;-1)
In excel it would look like this:
Table with parameter change:
Table with unique products and Xlookup value
I would like to do this directly in Power Bi so we don't get another excel table that we need to keep updated.
Thanks in Advance!
Hi @LiMa92 ,
This is table1:
This is table2:
Please create a new column in table2:
Column = LOOKUPVALUE('table1'[value],'table1'[Date],'table2'[Date])
If I misunderstood your needs, please contact us in time.
Best regards,
Yadong Fang
Hi @LiMa92 ,
This is table1:
This is table2:
Best regards,
Yadong Fang
Hi Yadong,
is it possible to somhow do this when the date and time is not matching exactly in the 2 tables?
in youre example:
I would like to make table 2 check the date in table 1 and if it´s not exactly matching then take the value from the closest older date and use that value instead.
Best Regards LM
15 | |
13 | |
8 | |
6 | |
6 |
24 | |
19 | |
12 | |
9 | |
7 |
