BJ_TS's avatar
BJ_TS
3 years ago
Problem counting number of rows when using Filter with AND-logic
Hi. I have a table "PersonCertificates" with two columns:
Person   Certificate
MrA   Cert1
MrA   Cert2
MrA   Cert3
MrB   Cert1
MrB   Cert2
MrC   Cert3
I have a slicer for Certificate and a table to list all Person(s).
With the help of the two measures below I can apply AND-logic so the table only lists all persons that have all the selected certificates:
_Number_of_selected_certificates := IF ( ISFILTERED ( 'PersonCertificates'[Certificate] ), COUNTROWS ( ALLSELECTED ( 'PersonCertificates'[Certificate] )), 0 )
_Person_Got_all_selected_certificates := IF ( [_Number_of_selected_certificates] = 0, 1, IF ( DISTINCTCOUNT ( 'PersonCertificates'[Certificate] ) = [_Number_of_selected_certificates], 1, 0 ))
I use {_Person_Got_all_selected_certificates is 1} as a filter on the table that lists all Person's and this works fine. If I select Cert1 and Cert3 in the slicer I only get Mr A in the list - as expected. But I also want to calculate the number of persons listed in the table and I can't get this to work. I use this measure to calculate rows:
Number of person :=
var vPersonTable = SUMMARIZE ( 'PersonCertificates', 'PersonCertificates'[Person], "Person Got All selected certificates", [_Person_Got_all_selected_certificates] )
return
CALCULATE ( COUNTROWS ( vPersonTable ), FILTER ( vPersonTable, [Person Got All selected certificates] = 1 ))
This measure returns 3 when I select Cert 1 and Cert 3 but only shows Mr A in the table.
How can i get this calculation to work?
Thanx!
//Henrik
    3 years ago
    Hi BJ_TS ,
    I have created a simple sample, please refer to it to see if it helps you.
    CountNumber =
    var _a = SELECTCOLUMNS('Table 2',"Certificate",[Certificate])
    return CALCULATE(DISTINCTCOUNT('Table'[Person]),FILTER(ALL('Table'),[Certificate] in _a))
    Name =
     var _a = SUMMARIZE(ALL('Table'),[Person],"Flag",CALCULATE(COUNT('Table'[Certificate]),FILTER(ALL('Table'),[Certificate] in SELECTCOLUMNS('Table 2',"Certificate",[Certificate])&&[Person]=EARLIER('Table'[Person]))))
     var _b = COUNTROWS(ALLSELECTED('Table 2'[Certificate]))
     return MAXX(FILTER(_a,[Person]=SELECTEDVALUE('Table'[Person])&&[Flag]=_b),[Person])
    If it does not help, please provide more details with your desired output and pbix file without privacy information (or some sample data) .
    Community Support Team _ Rongtie
1 Reply
    Hi BJ_TS ,
    CountNumber =
    Name =
