Hi Folks,
I have a requirement to convert all measurementquantityamount of MT,M3,USG to BBL,
we need to show all MT,M3,USG quantityamount in BBL quantityamount.
Example:
1 BBL = 0.1183432 MT,
1 BBL= 0.159 M3,
1BBL = 42 USG
Below is the Screeenshot of source in different formats MT,M3,USG and BBL need to convert to all to BBL measuremtnquantityamount .
We need to show all M3,MT,USG in BBL quantityamount, Need solution in DAX or method to achieve this.
SBC
Hi @SBC
Another way is to have a "Conversion" table linked with your table
Measuring Unit | Converion Factor |
MT | 0.1183432 |
M3 | 0.159 |
USG | 42 |
BBL | 1 |
Then you can link Converion[Measuring Unit] with TableName[MsrmntQtyUom] (One - Many single way realtionship)
Then use
BBLMsrmntQtyAmt = TableName[MsrmntQtyAmt] * RELATED ( Converion[Converion Factor] )
Hi @SBC
MT | 0.1183432 |
M3 | 0.159 |
USG | 42 |
BBL | 1 |
Then use
Hi @tamerj1 ,
I have tried this method ,works fine for MT,M3 and USG,But for BBL it is showing blank values instead of displaying the associated values .as below screenshot.
SBC
@SBC
You can add a calculated column as follows:
Conversion =
VAR __FACTOR = SWITCH ( 'table'[MsrmntQtyUom], "MT", 0.1183432, "M3" = 0.159, "USG" = 42, "BBL", 1 )
VAR __RESULT = DIVIDE('table'[MsrmntQtyAmnt], __FACTOR )
__RESULT
⭕ Subscribe and learn Power BI from these videos
⚪ Website ⚪ LinkedIn ⚪ PBI User Group
10 | |
7 | |
5 | |
4 | |
3 |
12 | |
11 | |
10 | |
9 | |
8 |
