Get Fabric Certified for FREE during Fabric Data Days. Don't miss your chance! Learn more
SBC
Helper III
Helper III
Need to Calculate conversion quantity in Power BI
Hi Folks,
I have a requirement to convert all measurementquantityamount  of MT,M3,USG to BBL,
we need to  show all MT,M3,USG  quantityamount  in BBL quantityamount.
Example:
1 BBL = 0.1183432 MT,
1 BBL= 0.159 M3,
1BBL = 42 USG
Below is the Screeenshot of source in different formats MT,M3,USG and BBL need to convert to  all to BBL measuremtnquantityamount .
We need to show all M3,MT,USG  in BBL quantityamount, Need solution in  DAX  or method to achieve this.
SBC
tamerj1
Hi @SBC
Another way is to have a "Conversion" table linked with your table
Measuring Unit Converion Factor
MT 0.1183432
M3 0.159
USG 42
BBL  1
Then you can link Converion[Measuring Unit] with TableName[MsrmntQtyUom] (One - Many single way realtionship)
Then use
BBLMsrmntQtyAmt = TableName[MsrmntQtyAmt] * RELATED ( Converion[Converion Factor] )
tamerj1
Hi @SBC
MT 0.1183432
M3 0.159
USG 42
BBL  1
Then use
Hi @tamerj1 ,
I have tried this method ,works fine for MT,M3 and USG,But for BBL it is showing blank values instead of displaying the  associated values .as below screenshot.
SBC
@SBC
Check the spelling. Could be spaces
Fowmy
@SBC
You can add a calculated column as follows:
Conversion  =
 VAR __FACTOR = SWITCH ( 'table'[MsrmntQtyUom], "MT", 0.1183432, "M3" = 0.159, "USG" = 42, "BBL", 1 )
    VAR __RESULT = DIVIDE('table'[MsrmntQtyAmnt], __FACTOR )
        __RESULT
