vtec35
Need help with Power BI: custom colors and shapes on maps
Hello everyone,
I'm trying to display a list of geolocated addresses on a Power BI map (I know how to do that), but I'm stuck on the point customization part.
👉 Context:
Main table with addresses, each with:
Column A → an attribute type (e.g., main category)
Column B → a second attribute (e.g., subtype or status)
In another file, I define:
a color for each value in column A
a shape for each value in column B
🎯 Objective:
Display each address on the map with a shape and color corresponding to these definitions, like pins of different colors and shapes on a paper map.
🚧 Problem encountered:
I can display my points on the map, but:
I can't apply the colors according to the definition table,
I can't find how to manage the different shapes (circle, triangle, square, etc.).
💡 Question:
Is there a way (via DAX, a custom field, or a third-party visualization) to link these attributes to the color and shape of a point on a Power BI map?
I'd like it to be dynamic: if the files are updated, the colors and shapes update automatically.
⚠️ Note: I'm French, so I may have to translate your answers.
Thanks in advance for your advice! 🙏
17 REPLIES 17
djurecicK2
 This feature is on the roadmap for Q1 2026https://roadmap.fabric.microsoft.com/?product=powerbi
Azure map visual markers
Customize markers in Azure map visual. Use new icons or your own images with more formatting options to make your map ready for reports.
Release Date:
Q1 2026
@vtec35
hi
Could you make a very simple example that I can easily use as inspiration?
Please create a Power BI file connected to external data in CSV format.
In this CSV, keep it very simple with 4–5 rows, using different addresses wherever you want.
In the CSV, include a name, an address, and a color (or color code).
The result in Power BI should display, on the map, a colored point at the correct address, matching the color requested in the CSV, and if possible, a tooltip showing the name.
If this works, just show me how you configured it. I will look at it by translating on my side. Thank you.
Hi  @vtec35
Based on your original requirement, I prepared a simple sample CSV dataset and reproduced the scenario in Power BI.
The sample file has been used to generate a map visual with correctly geocoded locations, color-coded markers, and name tooltips.
I am sharing both the sample data and the output visual so you can refer to them as an example for your implementation.
Expected Output :
Attached the Sample file as below..
Hope this helps !!
Thank You.
hi we do that
https://we.tl/t-kpu1cR3Xss
that work perfectly for colour, about form chat gpt suggest  something but i understand nothing
Power BI – How to assign shape + color per point from Excel (Recommended approach)
Power BI native map visuals (Map / Azure Maps) do not support assigning different shapes per data row.
They only allow fixed symbols or category-based legends.
👉 Recommended solution: use the Deneb custom visual (Vega-Lite).
Why Deneb
  • Supports data-driven shapes and colors
  • Reads hex colors directly from a text column (#RRGGBB)
  • No manual rules, no SWITCH / IF
  • Fully scalable and maintainable
    Excel columns example
    latitude | longitude | hex_color | shape | tooltip
    Supported shapes
    circle, square, triangle, diamond, cross, star
    How it works
    • Install Deneb from AppSource
    • Use Vega-Lite
    • Bind:
      • color → hex color field (scale = null)
      • shape → shape field
        This is currently the only native Power BI solution that allows per-row symbol shapes + colors driven directly by data.
vtec35
Hello, I just opened the example file, but I don't have the accompanying Excel or CSV file to test the statuses and see if the response is as expected.
I'll try to create a very simple Excel file for you to test in English.
Hi @vtec35
Thanks for checking the example file! Sure a simple sample Excel file will be perfect.
Could you please include:
• A few rows that show the different statuses you are expecting.
• An example of the expected output so I can validate the logic accurately.
Once I have that, I’ll test the behavior and share the corrected solution.
looking forward for your response !
vtec35
ok i will resend you my excel file only for translate, i have use formula =translate, and it work perfectly
i have write with chat gpt what i want explain
I would like to create a Power BI report based on an Excel file structured as follows:
1. Data Sources
  • Lists tab: values used for dropdown menus (statuses, types, etc.).
  • Prescribers tab: prospects considered as prescribers (address, status, notes, contact…).
  • Potential distributors tab: prospects considered as potential points of sale.
  • Status–color mapping tab: a table linking each status to a specific color.
2. Objective
Build 3 maps in Power BI:
  1. Prescribers Map
    • Shows prescribers only
    • Shape: square
    • Color: depends on status (from mapping table)
  2. Potential Distributors Map
    • Shows points of sale only
    • Shape: circle
  3. Combined Map
    • Shows both categories
    • Uses the appropriate shapes (square/circle) and colors
3. Expected Behavior
  • Each point must be positioned according to its address.
  • Tooltips should display:
    • Contact name (or company name)
    • “Notes” field
  • Filters should use values from the “lists” tab.
4. Requirements
  • The report must read data directly from the Excel file.
  • Easy refresh when the Excel file is updated.
  • Clear and readable visual layout.
https://we.tl/t-TIbT03nkeU
Hi @vtec35
Thank you for sharing the details. To better understand your scenario and help you more effectively, could you please provide a small sample dataset that clearly represents your real structure?
This will allow us to reproduce the issue accurately.
How to provide sample data in the Power BI Forum - Microsoft Fabric Community
vtec35
Hello everyone, I'm sorry I've been a bit busy with various issues to resolve. I'm back now, so I'm going to send you my file in English.
theov
Advocate III
Advocate III
On the map, I'm not sure if it works but for KPIs, this works well: https://youtu.be/vv1RUpgodoE?si=PxzC7kO1Pvi7jyOO
vtec35
i can share my exemple file with linked csv file
https://we.tl/t-5YtXjpJ7ax
djurecicK2
Hi @vtec35 ,
 For colors, you can do something like the attached- look at the Colors setting under Bubble Layer on the Visuals tab. I don't think there is a way to do custom shapes the same way.
Hi @vtec35
Just checking in to see if the previous response helped resolve your issue. If not, feel free to share your questions and we’ll be glad to assist.
i can share my test file with you
Hi @vtec35
Thanks for sharing the PBIX file. I noticed that the dataset and report content appear to be in a different language. To help us better understand and reproduce the scenario accurately, could you please share the same file or a sample version of it in English ?
Hi @vtec35
To better reproduce and troubleshoot your scenario, we kindly request a small sample dataset/file. Please share it at your convenience, as this will help us provide a more accurate and tailored solution.
Hi @vtec35
Have you had a chance to look through the responses shared earlier?
looking forward for your response ?
