kailash2908
Need help in calculating SUM and AVERAGE for below problem Statement in DAX
I Have below query to solve in Power bi using DAX :
I have a table with transactions amount ,transaction dates with payer and vendor id, I have closed dates for payer , payee combination ..
I need to find the sum oflast 12 months transaction amount , if difference between closed dated and earliest transaction date goes back more than 24 months,
I need to find last 6 months average of transaction amount , if difference between closed dated and earliest transaction date goes back between 12 and 23 months
I need this calculation in a single column
Example Table :
Table 1:
Payer
Vendor
Transaction DATE
Closed Date
Transaction Amount
111
123
9/20/2024
9/22/2024
100
111
123
10/22/2023
9/22/2024
20
111
123
5/22/2023
9/22/2024
100
111
123
6/22/2021
9/22/2024
200
111
123
5/22/2021
9/22/2024
300
111
555
8/20/2024
8/31/2024
500
111
555
7/20/2024
8/31/2024
600
111
555
6/20/2024
8/31/2024
700
111
555
2/20/2024
8/31/2024
800
Resulting Matrix I need :
Payer VendorEarliest Transaction DATEClosed DateDiff Between DatesCalculated Amount
1111235/22/20219/22/2024Greater than 24120(This is Sum of Last 12 months)
1115555/20/20248/31/2024Greatre than 12 less than 23 550(This average of last 6 months)
If you want 720 on Total row, please check the below picture and the attached pbix file.
If this post helps, then please consider accepting it as the solution to help other members find it faster, and give a big thumbs up.
Click here to visit my LinkedIn page
Click here to schedule a short Teams meeting to discuss your question.
7 REPLIES 7
dharmendars007
Hello @kailash2908 ,
I see there the earliest dates you have mentioned for vendor "555" is not present in the table you have provided "5/20/2024' therefore Average is coming blank, kindly check this..
Apart from that based on other criteria i was able to create measure please check this and use this pattern to further modify your measure.
Measure 1
Earlydate = CALCULATE(MIN('Table'[Transaction DATE]),
                                    ALLEXCEPT('Table', 'Table'[Payer], 'Table'[Vendor]))
Measure 2
Diff Between Dates = DATEDIFF([Earlydate], MAX('Table'[Closed Date]), MONTH)
Measure 3 (Combine 1 and 2 )
Values =
VAR EarliestDate = [Earlydate]
VAR ClosedDate = Max('Table'[Closed Date])
VAR DiffMonths = [Diff Between Dates]
VAR Last12MonthsAmount =
    CALCULATE(
        Sum('Table'[Transaction Amount]),
        FILTER(
            'Table','Table'[Transaction DATE] >= EDATE(ClosedDate, -12)))
VAR Last6MonthsAverage =
    CALCULATE(
    AVERAGE('Table'[Transaction Amount]),
    FILTER(
        'Table',
        'Table'[Transaction DATE] <= MAX('Table'[Closed Date]) &&
        'Table'[Transaction DATE] >= EDATE(MAX('Table'[Closed Date]), -6)))
        IF(DiffMonths > 24, Last12MonthsAmount,
            IF(
            DiffMonths >= 12 && DiffMonths <= 23, Last6MonthsAverage, BLANK()))
If you find this helpful , please mark it as solution which will be helpful for others and Your Kudos/Likes are much appreciated!
Thank You
Dharmendar S
LinkedIN
Jihwan_Kim
I am not sure if I understood your question correctly, but I tried to create a sample pbix file like below, and I hope you can start from the below to make the result as you expected. Please check the below picture and the attached pbix file.
Total is 2720 , it should be 720
This worked , Thank you so much
dharmendars007
Measure 1
Measure 2
Values =
    CALCULATE(
        FILTER(
    CALCULATE(
    FILTER(
        'Table',
            IF(
Thank You
Dharmendar S
LinkedIN
Total is wrong right it is showing 2720, ideally it should be 120 in the total
