I Have below query to solve in Power bi using DAX :
I have a table with transactions amount ,transaction dates with payer and vendor id, I have closed dates for payer , payee combination ..
I need to find the sum oflast 12 months transaction amount , if difference between closed dated and earliest transaction date goes back more than 24 months,
I need to find last 6 months average of transaction amount , if difference between closed dated and earliest transaction date goes back between 12 and 23 months
I need this calculation in a single column
Example Table :
Table 1:
Payer | Vendor | Transaction DATE | Closed Date | Transaction Amount |
111 | 123 | 9/20/2024 | 9/22/2024 | 100 |
111 | 123 | 10/22/2023 | 9/22/2024 | 20 |
111 | 123 | 5/22/2023 | 9/22/2024 | 100 |
111 | 123 | 6/22/2021 | 9/22/2024 | 200 |
111 | 123 | 5/22/2021 | 9/22/2024 | 300 |
111 | 555 | 8/20/2024 | 8/31/2024 | 500 |
111 | 555 | 7/20/2024 | 8/31/2024 | 600 |
111 | 555 | 6/20/2024 | 8/31/2024 | 700 |
111 | 555 | 2/20/2024 | 8/31/2024 | 800 |
Resulting Matrix I need :
Payer | Vendor | Earliest Transaction DATE | Closed Date | Diff Between Dates | Calculated Amount | |
111 | 123 | 5/22/2021 | 9/22/2024 | Greater than 24 | 120 | (This is Sum of Last 12 months) |
111 | 555 | 5/20/2024 | 8/31/2024 | Greatre than 12 less than 23 | 550 | (This average of last 6 months) |
If you want 720 on Total row, please check the below picture and the attached pbix file.
Hello @kailash2908 ,
I see there the earliest dates you have mentioned for vendor "555" is not present in the table you have provided "5/20/2024' therefore Average is coming blank, kindly check this..
Apart from that based on other criteria i was able to create measure please check this and use this pattern to further modify your measure.
Measure 1
If you find this helpful , please mark it as solution which will be helpful for others and Your Kudos/Likes are much appreciated!
Thank You
Dharmendar S
I am not sure if I understood your question correctly, but I tried to create a sample pbix file like below, and I hope you can start from the below to make the result as you expected. Please check the below picture and the attached pbix file.
Total is 2720 , it should be 720
This worked , Thank you so much
Measure 1
Thank You
Dharmendar S
Total is wrong right it is showing 2720, ideally it should be 120 in the total
10 | |
8 | |
6 | |
4 | |
3 |
