@ahmad1111 Create a calculated column to determine if the delivery is on time or not.
dax
OTD =
VAR Priority = 'Table1'[Priority]
VAR Diff = 'Table1'[DIFF]
VAR DayPOD = 'Table1'[DAYPOD]
VAR IsWeekend = IF(DayPOD = "Saturday" || DayPOD = "Sunday", 1, 0)
VAR AdjustedDiff =
IF(Priority <= 3,
Diff - COUNTROWS(
FILTER(
CALENDAR('Table1'[OrderDate], 'Table1'[EventDate]),
WEEKDAY([Date], 2) > 5
Diff
IF(
(Priority <= 3 && AdjustedDiff <= 5) ||
(Priority >= 4 && Diff <= 1),
"OnTime",
"NotOnTime"
Proud to be a Super User! |
Hi @ahmad1111 ,
Based on the information, try using the following DAX formula.
OTD =
VAR IsWeekend = (DayPOD = "Saturday" || DayPOD = "Sunday")
VAR OnTimeCondition =
SWITCH(
TRUE(),
Priority <= 3 && Diff <= 5 && !IsWeekend, "OnTime",
Priority > 3 && Diff <= 1, "OnTime",
TRUE, "NotOnTime"
RETURN OnTimeCondition
If the DAX formula is wrong or doesn't work, please provide example data.
Wisdom Wu
dax
OTD =
VAR AdjustedDiff =
IF(Priority <= 3,
Diff - COUNTROWS(
FILTER(
Diff
IF(
"OnTime",
"NotOnTime"
Got error
@ahmad1111 , Check dates mentioned inside calender formular, Start date is after end date
my dates i am testing with currently is as follows Created On is the Order Date and Timestamp is eventdate note that is my data source this from excel
Created On | Timestamp |
01/06/25 | 01/07/25 |
01/19/25 | 01/21/25 |
01/05/25 | 01/09/25 |
01/03/25 | 01/03/25 |
01/21/25 | 01/22/25 |
01/16/25 | 01/17/25 |
01/19/25 | 01/22/25 |
01/16/25 | 01/21/25 |
hi bhanu i checked it should be correct but weird thing is if i change OrderDate which i dont want to but i tested and made it date 01.01.2025 manual instead of OrderDate error goes away but i want to keep that orderdate see in my excel sheet if i make it same as today date or close to it it gives that same error again is there a work around this?
22 | |
11 | |
8 | |
6 | |
6 |
26 | |
13 | |
11 | |
9 | |
6 |
