ahmad1111
Need Help on some DAX command or solution way around my issue
Hi so i am trying to do some calculation for transportation operation team and i got stuck with something bit hard for me also to note i tried switch it wont work and gives wrong value and things going fine with the nested IF anyways priority i have 1&2 is normal 3 is hot taxi and 4&5 is emergency also DAYPOD basically is giving me based on the event date i have instead of date format of 12/12/2024 for ex it change it to its day and for DIFF is the difference in days between event date - creation of order date and so my intended final result i want is to calculate what is on time and what is not on time based on if
I need to check if its 1&2&3 priority then allowed delivery days is 5 not more and should not include/Skip weekend then its on time otherwise if its more than 5 days its not on time so in short 5 days skipping weekend if i get order thursday then it should calculate it like thus,sun,mon,tue,wed (5)
For 4&5 priority then it should include weekend
(((NOTE THAT priority was in my data source column and rest was custom column created by me)))
OTD = IF(
'Table1'[Priority] <= 2 && 'Table1'[DIFF] <= 5 && 'Table1'[DAYPOD] <> "Friday" && 'Table1'[DAYPOD] <> "Saturday","OnTime",
IF('Table1'[Priority] > 2 && 'Table1'[DIFF] <= 1,"OnTime",
IF('Table1'[Priority] <= 2 && 'Table1'[DIFF] > 5,"NotOnTime",
IF('Table1'[Priority] = 3 && 'Table1'[DIFF] > 1,"NotOnTime",
IF('Table1'[Priority] >= 4 && 'Table1'[DIFF] > 1,"NotOnTime",
IF('Table1'[Priority] >= 3 && 'Table1'[DIFF] < 1,"OnTime",
IF('Table1'[Priority] <= 2 && 'Table1'[DIFF] < 1,"OnTime"
bhanu_gautam
@ahmad1111 Create a calculated column to determine if the delivery is on time or not.
dax
OTD =
VAR Priority = 'Table1'[Priority]
VAR Diff = 'Table1'[DIFF]
VAR DayPOD = 'Table1'[DAYPOD]
VAR IsWeekend = IF(DayPOD = "Saturday" || DayPOD = "Sunday", 1, 0)
VAR AdjustedDiff =
IF(Priority <= 3,
Diff - COUNTROWS(
FILTER(
CALENDAR('Table1'[OrderDate], 'Table1'[EventDate]),
WEEKDAY([Date], 2) > 5
Diff
IF(
(Priority <= 3 && AdjustedDiff <= 5) ||
(Priority >= 4 && Diff <= 1),
"OnTime",
"NotOnTime"
Did I answer your question? Mark my post as a solution! And Kudos are appreciated
LinkedIn
Hi @ahmad1111 ,
Based on the information, try using the following DAX formula.
OTD =
VAR IsWeekend = (DayPOD = "Saturday" || DayPOD = "Sunday")
VAR OnTimeCondition =
    SWITCH(
        TRUE(),
        Priority <= 3 && Diff <= 5 && !IsWeekend, "OnTime",
        Priority > 3 && Diff <= 1, "OnTime",
        TRUE, "NotOnTime"
RETURN OnTimeCondition
If the DAX formula is wrong or doesn't work, please provide example data.
Wisdom Wu
bhanu_gautam
dax
OTD =
VAR AdjustedDiff =
IF(Priority <= 3,
Diff - COUNTROWS(
FILTER(
Diff
IF(
"OnTime",
"NotOnTime"
LinkedIn
Got error
@ahmad1111 , Check dates mentioned inside calender formular, Start date is after end date
LinkedIn
my dates i am testing with currently is as follows Created On is the Order Date and Timestamp is eventdate note that is my data source this from excel
Created OnTimestamp
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/19/2501/21/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/06/2501/07/25
01/05/2501/09/25
01/03/2501/03/25
01/05/2501/09/25
01/21/2501/22/25
01/16/2501/17/25
01/06/2501/07/25
01/19/2501/22/25
01/16/2501/21/25
hi bhanu i checked it should be correct but weird thing is if i change OrderDate which i dont want to but i tested and made it date 01.01.2025 manual instead of OrderDate error goes away but i want to keep that orderdate see in my excel sheet if i make it same as today date or close to it it gives that same error again is there a work around this?
