I need some assistance. My Daily Total column doesn't account for selected values in my slicer. When a item is selected the totals do not recalculate.
Can someone assist?
Daily Total =
var fdate = MIN([activity_dt])
var ldate = MAX([activity_dt])
var rowdate= [activity_dt]
var finalrange = IF(DATEDIFF(fdate, rowdate, DAY) < 7, DATEDIFF(fdate, rowdate, DAY), 7)
var FilterTable = FILTER(Sheet1, [activity_dt] = rowdate)// >= rowdate-finalrange && [activity_dt] <= rowdate)
return
CALCULATE(SUM([Gross_adds]), Filtertable)The output here is as followed:
Daily Total: Is a running total of all categories and does not update regardless of what you select in the slicer.
Correct Daily Total: Is what I would like to see when I select 4 of those categories
No worries. I figured it out yesterday. The updates should have been made in my 7 Day Running column (not shared) instead of the Daily Totals. In that code, the rowdate and finalrange is applied to where its less confusing.
7 Day running =
var service = [service]
var FilterTable = FILTER(Sheet1, [activity_dt] >= rowdate-finalrange && [activity_dt] <= rowdate && [service] = service)
var datatotals = CALCULATE(SUM([Gross_adds]), Filtertable)
var results = if(finalrange <=0 , datatotals, datatotals/( finalrange+1))
return
results
Hi , @Anonymous
I am so glad that you have solved your issue . Please consider Accept it as the solution to help the other members find it more quickly.
Hi @Anonymous
Looking at your DAX, I have a few questions .
(1)I don't quite understand the meaning of rowdate, when you select multiple, this value will show null value. So, what are you getting this value for ?
(2)If the value of finalrange is greater than or equal to 7 , how did you count the sum of [Gross_adds] ?
From the correct daily totals you provided , it seems to be the sequential addition of the values you selected . So I am confused and hope you can give a detailed explanation .
7 Day running =
return
results
| 5 | |
| 5 | |
| 5 | |
| 4 |
| 24 | |
| 21 | |
| 15 | |
| 12 | |
| 10 |
