Max gap between 2 values using DAX
Hi all,
I am trying find the maximum gap between 2 values, but that excludes Saturday and Sunday.
Eg:
 SunMonTueWedThurFriSat
1FTFFFFF
2FTTTFFF
3FTTTTTF
In the above table, I would like to calculte the max gap between 2 T's (Sat and Sun excluded)
So in the first row, the max gap will be 5
In the second row the max gap will be 3
In the third row the max gap will be 1
Can I please if it is possible to implement this in DAX?
If so, can i please understand on how to implement?
Any help is appreciated!
Thank you!
Megha
Icey
Hi @Anonymous ,
In your sample, try to create a custom column in Power Query Editor like so:
= List.Count(List.Select(Record.ToList(Record.SelectFields(_,{"Monday","Tuesday","Wednesday","Thursday","Friday"})), each _ =  "F"))+1
In addition, here is the complete query and you can create a blank query and paste it.
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUXID4hAojYpjdaKVjJBUhGCoBKkwxqICoTI2FgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Name = _t, Sunday = _t, Monday = _t, Tuesday = _t, Wednesday = _t, Thursday = _t, Friday = _t, Saturday = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Name", Int64.Type}, {"Sunday", type text}, {"Monday", type text}, {"Tuesday", type text}, {"Wednesday", type text}, {"Thursday", type text}, {"Friday", type text}, {"Saturday", type text}}),
    #"Added Custom" = Table.AddColumn(#"Changed Type", "Max Gap", each List.Count(List.Select(Record.ToList(Record.SelectFields(_,{"Monday","Tuesday","Wednesday","Thursday","Friday"})), each _ =  "F"))+1)
    #"Added Custom"
Icey
Jihwan_Kim
I am not sure if I understood your question correctly, but please check the below picture and the attached pbix file.
Max gap between two Ts: =
IF (
    HASONEVALUE ( Data[Row Index] ),
        COUNTROWS ( 'Weekday' ),
        FILTER ( RELATEDTABLE ( Data ), Data[Value] <> "T" )
    ) - 1
If this post helps, then please consider accepting it as the solution to help other members find it faster, and give a big thumbs up.
Click here to visit my LinkedIn page
Click here to schedule a short Teams meeting to discuss your question.
Thank you! @Jihwan_Kim
The table is in this format and there are multiple values.
Is there a way I can get the maximum gap in the same way without changing the format?
Thank you!
Megha
Icey
Hi @Anonymous ,
    #"Added Custom"
Icey
