Hi so below are just small example of but dont take the cells with from and to and distance as the correct ones but i just posted it as example because i have big data 5000 rows in my excel so what i actually need is i get an order that order will have plant and unloading point code (as my site name thus from all 5000 rows you can get any for example from below point A is lets say A001-422 and point B is A001-422/477 and issue is since data is big i cant just go one site and check with all other 4999 rows to see which city each site belongs to so i need a way for power bi to check when an order comes and excel updates which is my data source and linked to my power bi then power bi should give me the fixed distance that i have in my excel thus distance only linked as city to city based and not site to site based which is what i recieve when order comes so in short order comes as site a to site b and i need to convert that site to its respective city that it belongs to based on the excel i have and then give the distance
Plant | Unloading Point Code | Unloading Point Name | Region | Country/Region Key | City | From Location | To Location | Distance In KM |
A001 | 422 | BERRI B-221 GAS PLANT MAINTENANCE | ZEA | SA | BERRI | |||
A001 | 422/470 | BERRI B-221 LIQUID RECOVERY (PLT 470) | ZEA | SA | BERRI | GHAZAL | 1,551 | |
A001 | 422/474 | BERRI GAS SWEETINING PLANT | ZEA | SA | BERRI | UTHMANIYAH | 227 | |
A001 | 422/476 | BERRI B-1054 UTILITIES PLANT | ZEA | SA | BERRI | BAISH | MAZALIJ | 1,234 |
A001 | 422/ACS | BERRI B-221, MAINTENANCE A/C SHOP | ZEA | SA | BERRI | BAISH | AL-MUBARRAZ | 1,394 |
A001 | 422/ELS | BERRI B-221, MAINTENANCE ELECTRICAL SHOP | ZEA | SA | BERRI | BAISH | BIRALGHANEM | 968 |
A001 | 422/ENG | BERRI B-221, GAS PLANT MAINTEMANCE | ZEA | SA | BERRI | BAISH | KHAMIS MUSHAIT | 165 |
A001 | 422/F13 | BERRI B-F14, RULF. PRILL PLANT F13 | ZEA | SA | BERRI | BAISH | MAZALIJ | 1,234 |
A001 | 422/F14 | BERRI B-F14, PLT F14 | ZEA | SA | BERRI | |||
A001 | 422/F18 | BERRI B-1054, F18 COGENERATION | ZEA | SA | BERRI | |||
A001 | 422/F20 | BERRI B-1054, ETHANE RECOVERY | ZEA | SA | BERRI | |||
A001 | 422/IED | BERRI B-201, INSTRUMENT & DIG SHOP | ZEA | SA | BERRI | |||
A001 | 422/MAS | BERRI B-201, ROTATING EQUIPMENT SHOP | ZEA | SA | BERRI | |||
A001 | 422/MCU | BERRI B-210, BGP MATL. COORDINATION UNIT | ZEA | SA | BERRI | |||
A001 | 422/MES | BERRI B-1053, MAINTENANCE METALS SHOP | ZEA | SA | BERRI | |||
A001 | 422/PIU | BERRI B-1054, USER PICK-UP | ZEA | SA | BERRI | |||
A001 | 422/R64 | BERRI B-471 SULFUR PLANT,ALLTRAIN PLT471 | ZEA | SA | BERRI | |||
A001 | 422/R68 | BERRI B-221, OFF-SITE ARE | ZEA | SA | BERRI | |||
A001 | 422/R69 | BERRI B-475, ETHANE PLANT PLT 475 | ZEA | SA | BERRI | |||
A001 | 422/RVS | BERRI B-201 RVS AT BERRI G. PLANT MAINT. | ZEA | SA | BERRI | |||
A001 | 422/T&I | BERRI B-221, T&I YARD | ZEA | SA | BERRI | |||
A001 | C300 | RASTANURA STORES | ZEA | SA | RAS TANURA | |||
A001 | C321 | JUAYMAH B-321, STORES | ZEA | SA | JUAYMAH | |||
A001 | C422 | BERRI GAS PLANT MAIN | ZEA | SA | BERRI | |||
A001 | H01A | JUAYMAH MSSD REVERSE ENGINEERING CENTER | ZEA | SA | JUAYMAH | |||
A002 | 531 | SHEDGUM STORES UNIT | ZEA | SA | SHEDGUM | |||
A002 | 532/TXI | UTHMANIYAH GAS PLANT TAXI MATERIALS | ZEA | SA | UTHMANIYAH | |||
A002 | 566 | UTHMANIYAH NGL FIRE CONTROL UNIT | ZEA | SA | UTHMANIYAH |
@ahmad1111 Create a table that maps each site to its respective city. This table will help you convert site codes to city names.
Create relationships between your main data table and the mapping table based on the site codes
Create calculated columns in your main data table to convert site codes to city names using DAX.
From City = RELATED('MappingTable'[City])
To City = RELATED('MappingTable'[City])
Create a measure to calculate the distance between cities. Assuming you have a table with distances between cities, you can use a DAX
Distance =
VAR FromCity = [From City]
VAR ToCity = [To City]
CALCULATE(
MAX('DistanceTable'[Distance In KM]),
'DistanceTable'[From Location] = FromCity,
'DistanceTable'[To Location] = ToCity
Proud to be a Super User! |
@bhanu_gautam thanks for your reply i got bit confused little bit is it possible to give me in steps mainly the first steps regarding creating table and relationships as i got lost with the mapping table and main data table as in do you mean main table is my excel with the sites and cities and distance and mapping table is a new table i create in power bi but if so then what do you put in it or do with it within power bi so steps will be very helpful thanks
14 | |
11 | |
8 | |
6 | |
5 |
28 | |
19 | |
14 | |
8 | |
5 |
