asdf1608
Helper V
Helper V
How to do unit conversion in power BI
I need to display values based on the particular unit conversion
The formula is value/Unit conversion.
I have created the parameter for unit conversion but not sure of how to include the both in same column.
How do I get this in power BI.
I have attached the sample power BI file.
Help with this is appreciated.
Thanks in advance
johnt75
Try
Converted value = SUMX(
	'Sheet1',
	DIVIDE(
		'Sheet1'[Value],
		SELECTEDVALUE( 'Unit Conversion'[Column2], 1 )
Can you please apply this in the power BI file so that it will be easy for me to check.
Please
Sample.pbix
FabCon Global Hackathon
