I need to display values based on the particular unit conversion
The formula is value/Unit conversion.
I have created the parameter for unit conversion but not sure of how to include the both in same column.
How do I get this in power BI.
I have attached the sample power BI file.
Help with this is appreciated.
Thanks in advance
Try
Converted value = SUMX(
'Sheet1',
DIVIDE(
'Sheet1'[Value],
SELECTEDVALUE( 'Unit Conversion'[Column2], 1 )
Can you please apply this in the power BI file so that it will be easy for me to check.
Please
10 | |
9 | |
7 | |
4 | |
4 |
