Help with dates range and zero values
Hi, this is the situation:
I have Sprint Days and I count the stories in those Sprints. The thing is that maybe in the first or two days of Sprints, there are no Stories. I have to show Zero in that days instead of blank.
Now, the measure looks like that, it has a condition to put blanks in those future days in the sprint where there are no data:
IF(MAX ( 'BuildBurnUp'[SprintDays])>Today(),BLANK(),CALCULATE (
     SUM('BuildBurnUp'[Actual Build Completed Stories]),
    FILTER (ALLSELECTED ('BuildBurnUp'[SprintDays]),'BuildBurnUp'[SprintDays] <= MAX ( 'BuildBurnUp'[SprintDays]))
So the missing part would be force zero values when the first days of Sprint has no data.
Thanks in advance
before asking question always share sampla data and expected output so that it will be easier for others to help you.
If you want replace those blanks with 0 in your formula then simple add 0 after if condition part instead of blank.
Thanks & regards,
Pravin Wattamwar
www.linkedin.com/in/pravin-p-wattamwar
If I resolve your problem Mark it as a solution and give kudos.
Thanks & regards,
Pravin Wattamwar
