Hi Team,
I need to calculate duration and aging based on the dates selected from the slicer Dateslicer (we used option as Between)
We are having fields like startdate and enddate columns in the source table.
Requirement
Slicer :
Duration in Days Calculation
For example: We are having
Startdate Enddate
01-Jan-2024 10-Jan-2024
We need to calculate duration for above record is diffference between these two dates :01-jan-2024 & 08-jan-2024 because we selected enddate as 8-jan-2024 from the slicer
Always StartDate>=Selected date from slicer
Enddate should be : <= selected date from the slicer
Power bI File Link : AgingDuration.pbix
Deva.
Hi @Anonymous ,
Can't open the pbix file you shared, please re-share it in another way and I'll get back to you as soon as possible.
Adamk Kong
You can let the data model help you, with USERELATIONSHIP
What's your formula for aging?
Hi @lbendlin ,
I've created relation in data model and created measure for duration.
We are using matrix visual to show the data . Duration is showing correctly in the detail level( last drill down level) while we drill up to above level duration showing wrong values(means its not summing up the data)
For example:
Deatil Level
These duration values(Highloghted in yellow) are calculating correctly
Drill Up Level
When we drill up the data showing wrong value )highlighted yellow)
we need to show : sum of 4.94+1.11
I tried in my way but unable to solve the issue . Can you please help on the same?
Measure name created in the attached file is: Duration_Day
Power file Link: AgingDuration.pbix
Deva.
Your slicer should be fed by a proper calendar table, not by
26 | |
10 | |
8 | |
6 | |
6 |
32 | |
14 | |
11 | |
10 | |
9 |
