Kudos to all power BI Professional, need some help here.
I have 2 tables:
1 tables contain a column with 4 digit number say 1234
I have another table with a column that contain all the permutation of number 1234 such as 1234,4321,2341,4123,3142,2143 and so on.
What i'm trying to achieve here is when i select the slicer value to 1234
Another visual will suggest all the related permutation 234,4321,2341,4123,3142,2143 so that i can pick each of them and display it on a visual bar chart, instead of me loccate individually what are the permutation of 1234.
Any suggestion that are able to check the related permutation solution is much appreciated!
Hi Johnt75, this seems like a good idea but i how do i perform the matching value ?
<Index Table> Permutation1 Permutation2 Permutation3
1234 3412 3124 2314
this should be the result for the solution you're suggesting but since i have 2 seperate table for the index table and permutation value, i couldn't find a way to match the value and compute such a table as suggested, any idea ?
In Power Query select the index column and then choose "unpivot other columns" so you are left with a table like
| Index column | Permutation |
| 1234 | 3412 |
| 1234 | 3142 |
| 1234 | 2314 |
You then set up a one-to-many relationship from your main data table to this new table and put the permutation column from this table into your visuals.
Transform your data so that instead of having an index value and a list of comma separated permutations you instead have a row for each index value & permutation combination. Then you can just link the slicer to the index column and that will display all the combinations.
| 8 | |
| 6 | |
| 5 | |
| 5 | |
| 4 |
| 25 | |
| 16 | |
| 8 | |
| 7 | |
| 7 |
