asdf1608
Helper V
Helper V
Facing problem in converting tableau calculated fields to power BI DAX measures
I am converting the tbleau measures to Power DAX measures. Help in this is needed.
1) column1 = DATEADD('hour',-6,[column2])
2)column3=
IF DATEPART('weekday',DATEADD('month',10,DATETRUNC('year',[[column1]))) = 1
THEN DATEADD('day',0,DATEADD('hour',2,DATEADD('month',10,DATETRUNC('year',[column1]))))
ELSE DATEADD('day',8-DATEPART('weekday',DATEADD('month',10,DATETRUNC('year',[column1]))),
END
 this is urgent.
Please Help.
Thanks in advance
lbendlin
Can you describe the business problem behind the formula?
@lbendlin  basically I need the datetrunc part.
In tableau datetrunc(year,column1)
For example if the date is 12/3/2021 after datetrunc if results "1/1/2021"
if the date is 3/5/2021 then the result is 1/1/2021
How to achieve this in power BI
DATE(YEAR([column1]),1,1)
