DAXUser
Display top 10 product without using dense and skip ranking
ProductTotal CountRankExpected Output
Screw6911
Spanners6822
Clutch6823
Cross6734
External Hex6645
Hex Socket6556
Square Socket6467
Tamper Resistant Hex6378
Torx6289
Slotted61910
One way601011
Plain601012
JIS601013
As you can see, I have a total count for each product in the table. I used the dense ranking based on the number of products. Now my requirement is I want to display first 10 products from the table which means I want to display continues number(1 to 10) similar to expected output column so that I will apply a filter on top of expected output column to get first 10 products.
2 ACCEPTED SOLUTIONS
@DAXUser , if this for meausre refer tie breaker
Rank Tie breaker
https://community.powerbi.com/t5/Community-Blog/Breaking-Ties-in-Rankings-with-RANKX-Using-Multiple-...
https://databear.com/how-to-use-the-dax-rankx-function-in-power-bi/
But if this column, then consider
Power Query Table.AddRankColumn : https://youtu.be/bnB1rgAhZaw
tamerj1
Hi @DAXUser
Please refer to attached sample file. You can use TOPN function in this case as folows (unless you need to show the rank in the visual):
Place the filter measure in the filter pane of the visual, select "is not blank" then apply the filter.
Top 10 Filter =
IF (
    SELECTEDVALUE ( Products[Product] )
        IN TOPN (
            10,
            ALLSELECTED ( Products[Product] ),
            [Total Count],,
            Products[Product]
    1
tamerj1
Hi @DAXUser
Top 10 Filter =
IF (
        IN TOPN (
            10,
            [Total Count],,
            Products[Product]
    1
Rank Tie breaker
