Product | Total Count | Rank | Expected Output |
Screw | 69 | 1 | 1 |
Spanners | 68 | 2 | 2 |
Clutch | 68 | 2 | 3 |
Cross | 67 | 3 | 4 |
External Hex | 66 | 4 | 5 |
Hex Socket | 65 | 5 | 6 |
Square Socket | 64 | 6 | 7 |
Tamper Resistant Hex | 63 | 7 | 8 |
Torx | 62 | 8 | 9 |
Slotted | 61 | 9 | 10 |
One way | 60 | 10 | 11 |
Plain | 60 | 10 | 12 |
JIS | 60 | 10 | 13 |
As you can see, I have a total count for each product in the table. I used the dense ranking based on the number of products. Now my requirement is I want to display first 10 products from the table which means I want to display continues number(1 to 10) similar to expected output column so that I will apply a filter on top of expected output column to get first 10 products.
@DAXUser , if this for meausre refer tie breaker
Rank Tie breaker
https://community.powerbi.com/t5/Community-Blog/Breaking-Ties-in-Rankings-with-RANKX-Using-Multiple-...
https://databear.com/how-to-use-the-dax-rankx-function-in-power-bi/
But if this column, then consider
Power Query Table.AddRankColumn : https://youtu.be/bnB1rgAhZaw
Hi @DAXUser
Please refer to attached sample file. You can use TOPN function in this case as folows (unless you need to show the rank in the visual):
Place the filter measure in the filter pane of the visual, select "is not blank" then apply the filter.
Top 10 Filter =
IF (
SELECTEDVALUE ( Products[Product] )
IN TOPN (
10,
ALLSELECTED ( Products[Product] ),
[Total Count],,
Products[Product]
1
Hi @DAXUser
Top 10 Filter =
IF (
IN TOPN (
10,
[Total Count],,
Products[Product]
1
Rank Tie breaker
