marie_joy's avatar
marie_joy
2 years ago
DAX: Achieve Running Total with Multi-Level Breakdown and Overall Totals
I'm looking to create a DAX formula in Power BI that calculates a running total but also provides breakdowns and overall sums at different levels. Here's the scenario:
  • I have tables named month_table and net_marg_product_lines.
  • month_table contains a column fy_month_number for month identification (fiscal year is from July 1st until June 30th).
  • net_marg_product_lines has columns for account_nb, product_code, fiscal_year, and amount.
Desired Outcome:
I want to achieve the following calculations:
  1. Running Total by Account and Product: The running total should consider previous months' data for each combination of account_nb and product_code.
  2. Total by Product (All Accounts): Calculate the sum of amount for all account_nb belonging to a specific product_code.
  3. Total for All Products (All Accounts): Calculate the sum of amount for all account_nb and all product_code for the current context (defined by fy_month_number and fiscal_year).
Current Formula:
I've tried the following formula, but if it does correctly sum by product types, it does not by account type. I do not understand why...
RunningTotalValue =
VAR _CurrentMonth = MAX(month_table[cy_month_number])
VAR _CurrentFiscalYear = MAX(net_marg_product_lines[fiscal_year])
    CALCULATE(
        SUM(net_marg_product_lines[amount]),
        FILTER(
            ALLSELECTED(month_table),
            month_table[fy_month_number] <= _CurrentMonth
        FILTER(
            ALLSELECTED(net_marg_product_lines),
            net_marg_product_lines[fiscal_year] = _CurrentFiscalYear
Example with two accounts and two products for July and August:
 July 2023July 2023July 2023August 2023 August 2023 August 2023
ProductIncomeTransportMargin (Total)IncomeTransportMargin (Total)
Gr-1350000-700034300390000 (July + August)-1400388600
Gr-27800-900690010000-15008500
TOTAL357800-7900349900400000-2900397100
  • marie_joy's avatar
    marie_joy
    I found a solution but I do not understand it. If I remove
            FILTER(
     from the DAX formula, I do have correct calculations...
    If anyone can explain why, I will greatly appreciate!
  • marie_joy Try with:
    RunningTotal =
    CALCULATE(
    FILTER(
    month_table[cy_month_number] <= MAX(month_table[cy_month_number])
    FILTER(
    net_marg_product_lines[fiscal_year] = MAX(net_marg_product_lines[fiscal_year])
    LastAvailableValue =
    VAR CurrentMonth = MAX(month_table[cy_month_number])
    VAR FiscalYear = MAX(net_marg_product_lines[fiscal_year])
    VAR LastMonthWithValue =
    CALCULATE(
    MAX(month_table[cy_month_number]),
    FILTER(
    ALL(net_marg_product_lines),
    net_marg_product_lines[fiscal_year] = FiscalYear &&
    net_marg_product_lines[amount] <> BLANK()
    VAR LastValue =
    CALCULATE(
    FILTER(
    ALL(month_table),
    month_table[cy_month_number] = LastMonthWithValue
    FILTER(
    IF(
    ISBLANK(SUM(net_marg_product_lines[amount])),
    LastValue,
    BBF
