I'm looking to create a DAX formula in Power BI that calculates a running total but also provides breakdowns and overall sums at different levels. Here's the scenario:
Desired Outcome:
I want to achieve the following calculations:
Current Formula:
I've tried the following formula, but if it does correctly sum by product types, it does not by account type. I do not understand why...
RunningTotalValue =
VAR _CurrentMonth = MAX(month_table[cy_month_number])
VAR _CurrentFiscalYear = MAX(net_marg_product_lines[fiscal_year])
CALCULATE(
SUM(net_marg_product_lines[amount]),
FILTER(
ALLSELECTED(month_table),
month_table[fy_month_number] <= _CurrentMonth
FILTER(
ALLSELECTED(net_marg_product_lines),
net_marg_product_lines[fiscal_year] = _CurrentFiscalYear
Example with two accounts and two products for July and August:
July 2023 | July 2023 | July 2023 | August 2023 | August 2023 | August 2023 | |
Product | Income | Transport | Margin (Total) | Income | Transport | Margin (Total) |
Gr-1 | 350000 | -7000 | 34300 | 390000 (July + August) | -1400 | 388600 |
Gr-2 | 7800 | -900 | 6900 | 10000 | -1500 | 8500 |
TOTAL | 357800 | -7900 | 349900 | 400000 | -2900 | 397100 |
@marie_joy Try with:
RunningTotal =
CALCULATE(
FILTER(
month_table[cy_month_number] <= MAX(month_table[cy_month_number])
FILTER(
net_marg_product_lines[fiscal_year] = MAX(net_marg_product_lines[fiscal_year])
LastAvailableValue =
VAR CurrentMonth = MAX(month_table[cy_month_number])
VAR FiscalYear = MAX(net_marg_product_lines[fiscal_year])
VAR LastMonthWithValue =
CALCULATE(
MAX(month_table[cy_month_number]),
FILTER(
ALL(net_marg_product_lines),
net_marg_product_lines[fiscal_year] = FiscalYear &&
net_marg_product_lines[amount] <> BLANK()
VAR LastValue =
CALCULATE(
FILTER(
ALL(month_table),
month_table[cy_month_number] = LastMonthWithValue
FILTER(
IF(
ISBLANK(SUM(net_marg_product_lines[amount])),
LastValue,
BBF
I found a solution but I do not understand it. If I remove
FILTER( ALLSELECTED(net_marg_product_lines), net_marg_product_lines[fiscal_year] = _CurrentFiscalYear
from the DAX formula, I do have correct calculations...
If anyone can explain why, I will greatly appreciate!
12 | |
12 | |
8 | |
8 | |
6 |
27 | |
19 | |
14 | |
11 | |
7 |
