Hello all,
I don't understand a thing from Calculate and Filter combinate :
I have a small table with 2 columns :
| Quarter | Value |
1 | 25 |
| 2 | 45 |
| 3 | 78 |
| 4 | 14 |
| 1 | 12 |
I am trying to calculate the sum of value for the last quarter selected by user (with a slicer from the report).
So If the user select only the quarter 1, sum = 25 + 12 = 37
If the user select only the quarter 3, 2 & 1, sum = 78 etc.
So I am using this Dax function :
@Lovebo01 , not very clear. When you select slicer value you do not need to filter. It should filter automatically.
When you use MAX(Quarter) in filter; it will take display row context. In case you use a measure. It might end up taking MAX(Quarter) as the static max value.
Yes but If I don't filter my data it will summarize all values and I don't want to have all the values summarized.
I just want the last quarter selected. So If I select on my slicer Quarter : 1,2,3
I want the sum of all value for Quarter 3 (the max)
I don't want the sum of all value for Quarter 1 + Quarter 2 + Quarter 3. -> That's what I have with the Max in a measure.
If the measure is a static value, why it sums all the value for all Quarter selected from the slicer ?
Thank you for your help,
Lovebo,
Try like
Value Last Quarter =
var _max = MAXX(allselected('Test'),'Test'[Quarter])
return
CALCULATE([sum value],
Filter('Test','Test'[Quarter]=_max))
or
return
Filter(allselected('Test'),'Test'[Quarter]=_max))
Thank you for your solution,
But I would like to know why we have different result depending on using measure or not, in this case.
More precisely, why this option with 2 measures doesn't work :
Thank you,
Lovebo,
| 11 | |
| 9 | |
| 9 | |
| 5 | |
| 4 |
| 27 | |
| 22 | |
| 20 | |
| 17 | |
| 12 |
