jaryszek's avatar
jaryszek
1 year ago
Using Power Query SDK
hi Guys, 1. I have a multiple connectors as *.pq files and want to import them into power bi desktop automatically (not manually one by one) and use in power bi service. I want to use cloud data,...
    1 year ago
    Hi jaryszek,
    It means that Power BI Desktop does not provide a built-in API to programmatically insert or modify Power Query (.m) code inside a ".pbix" file, but using Power BI Templates (.pbit) allows you to store queries separately from data, making it easier to manage and reuse them across reports.
    To integrate .pq files into a development pipeline, you can:
    * Merge .pq files into a single .m script and store it in version control (e.g., Git, Azure DevOps).
    * Use a ".pbit" template containing predefined queries to create reports dynamically.
    * Then use PowerShell or Power BI REST API to create ".pbux" reports dynamically from the
       template.
    * Once the ".pbix" file is created, you can publish it automatically using the Power BI REST API or
       PowerShell.
    If I misunderstand your needs or you still have problems on it, please feel free to let us know.
    Hammad.
    Community Support Team
    If this post helps then please mark it as a solution, so that other members find it more quickly.
