E12345's avatar
E12345
Icon for Resolver II rankResolver II
11 months ago
I need help with using Power Query
I have a table which I need to make usable for Power BI. The table is in Excel, and it has double headers. The top column is Year, and underneath each year there are two more columns - Course and Completions. Can you help me make this into a table that lets me use the data inside Power BI?  need this data converted into three columns: Year, Course and Completions.
Below is the data Sample - Thank You! Is it possible provide a solution with GUI steps only (not M code or Advanced Editor)?
What if Another year is added (2026) - can the ETL be dynamic enough to account for another year?
2025202420232022
CourseCompletionsCourseCompletionsCourseCompletionsCourseCompletions
Course A34Course C126Course A56Course K123
Course B45Course B89Course B55Course B234
Course C56Course F77Course C77Course C34
Course D67Course D100Course J48Course J45
Original Data Looks like this in Excel.
  • Hi E12345, you need a combination of transpose/pivot/filldown to achieve what you are trying to do
    Step 1: Your starting point should look like this ideally => years not in the headers, so we can easily use Transpose + Fill Down in the next steps:
    Step 2: Click on Column1 and apply Transform > Transpose. This will give you a new Column1 with one row for each year + a blank row below it. Use Transform > Replace Value if the empty rows (2, 4, 6 and 😎 are not null but blank (= look empty)
    Step 3: Select Column1 and apply Transform > Fill > Down to fill the year-values into your null-rows:
    Step 4: Select Column1 + Column2 and apply Transform > Unpivot Columns > Unpivot other Columns:
    Step 5: Now Select Column2 (the one with the the values Course and Completions) and apply Transform > Pivot Column. Set the "Values Column" to "Value" (the one with Course A, 34 etc) and open the Advanced options to select "Don't Aggregate"
    Step 6: Rename the Columns as needed, delete the extra column "Attribute" and adjust the datatypes as needed:
    I hope that helps!
  • Here you go. All through the UI. No manual M coding needed.
        Source = Excel.CurrentWorkbook(){[Name="myData"]}[Content],
        #"Transposed Table" = Table.Transpose(Source),
        #"Filled Down" = Table.FillDown(#"Transposed Table",{"Column1"}),
        #"Merged Columns" = Table.CombineColumns(Table.TransformColumnTypes(#"Filled Down", {{"Column1", type text}}, "en-001"),{"Column1", "Column2"},Combiner.CombineTextByDelimiter(":", QuoteStyle.None),"Header"),
        #"Transposed Table1" = Table.Transpose(#"Merged Columns"),
        #"Promoted Headers" = Table.PromoteHeaders(#"Transposed Table1", [PromoteAllScalars=true]),
        #"Added Index" = Table.AddIndexColumn(#"Promoted Headers", "Index", 0, 1, Int64.Type),
        #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Added Index", {"Index"}, "Attribute", "Value"),
        #"Split Column by Delimiter" = Table.SplitColumn(#"Unpivoted Other Columns", "Attribute", Splitter.SplitTextByDelimiter(":", QuoteStyle.Csv), {"Attribute.1", "Attribute.2"}),
        #"Pivoted Column" = Table.Pivot(#"Split Column by Delimiter", List.Distinct(#"Split Column by Delimiter"[Attribute.2]), "Attribute.2", "Value"),
        #"Removed Columns" = Table.RemoveColumns(#"Pivoted Column",{"Index"}),
        #"Renamed Columns" = Table.RenameColumns(#"Removed Columns",{{"Attribute.1", "Year"}})
        #"Renamed Columns"
    This will take the grey data (named range "myData") to the green table.
    • E12345's avatar
      E12345
      I cannot recreate it... My table looks weird when I merge. I will try again later.
      UPDATE: I was able to recreate! THANK YOU SO MUCH!!!! This worked perfectly!
    I hope that helps!
    • E12345's avatar
      E12345
      Thank you so much!!! I followed your steps and it worked!
  • E12345
    Input data
    Output results
    Please find the code
      Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("pY69DsIwDIRfpfLcIXXi/owliAEeIcrYAQmaipb3x+6QvxXJw33n09nOASokaIGHlYlKR4WifOvAhu9nX5hseG+v5XiGdT/pbzu1NzOvtInBxrLssE+GBCjjxxnQeceFLUMpIjxOJVO1Rz6aVdjqyo3lMJRv1Vw2XNnps4Rwp1Qy7vLlWDGB9z8=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t, Column2 = _t, Column3 = _t, Column4 = _t, Column5 = _t, Column6 = _t, Column7 = _t, Column8 = _t]),
      #"Kept top rows" = Table.FirstN(Source, 2),
      #"Transposed table" = Table.Transpose(#"Kept top rows"),
      #"Replaced value" = Table.ReplaceValue(#"Transposed table", "", null, Replacer.ReplaceValue, {"Column1"}),
      #"Filled down" = List.Transform(Table.Split(Table.FillDown(#"Replaced value", {"Column1"}),2), each List.Transform(Table.ToColumns(_), each  List.Distinct(_) )),
      #"Removed top rows" = Table.Skip(Source, 2),
      ColumsnAndYear = List.Split(Table.ToColumns(#"Removed top rows"),2),
      #"Converted to table" = Table.FromList(ColumsnAndYear, Splitter.SplitByNothing()),
      #"Added index" = Table.AddIndexColumn(#"Converted to table", "Index", 0, 1, Int64.Type),
      #"Added custom" = Table.AddColumn(#"Added index", "Custom", each let
    columns = #"Filled down"{[Index]}{1},
    year = #"Filled down"{[Index]}{0}{0},
    result = Table.AddColumn(Table.FromColumns([Column1],columns),  "Year" ,each year)
    result),
      Custom = Table.Combine(#"Added custom"[Custom])
      Custom
    Connect on LinkedIn
    If I helped you, click on the Thumbs Up to give Kudos.
  • Hi,
    here is my Solution:
        Quelle = Excel.CurrentWorkbook(){[Name="Tabelle1"]}[Content],
        HeaderHoch = Table.PromoteHeaders(Quelle, [PromoteAllScalars=true]),
        Topics = Table.ColumnNames(Quelle),
        #"Sortierte Elemente" = List.Sort(Topics,Order.Ascending),
        TNSpalten = List.Skip(#"Sortierte Elemente",List.Count(#"Sortierte Elemente")/2),
        Jahre = {Number.From(Topics{0})..Number.From(Topics{List.Count(Topics)-2})},
        AnzK =List.Count(HeaderHoch[Kurs])-1,
        AnzJ = List.Count(Jahre)-1,
        Ausgabe =
            List.Generate
                () => [Kurs = 0, Jahr = 0],
                each [Jahr] <= AnzJ ,
                each
                        Kurs = if [Kurs] < AnzK then  [Kurs] + 1 else  0,
                        Jahr = if [Kurs] = AnzK then [Jahr] + 1 else [Jahr]
                each    [
                            Jahr = Jahre{[Jahr]} ,
                            Kurs = Record.Field(Quelle{[Kurs]+1}, Text.From(Jahre{[Jahr]})),
                            Teilnehmer = Record.Field(Quelle{[Kurs]+1}, TNSpalten{[Jahr]})
                            // Record.Field(Quelle{[Kurs]+1}, TNSpalten{[Kurs]})
        NewTopics ={"Jahr","Kurs","Teilnehmer"},
        #"In Tabelle konvertiert" = Table.FromList(Ausgabe, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
        #"Erweiterte Column1" = Table.ExpandRecordColumn(#"In Tabelle konvertiert", "Column1", NewTopics, NewTopics)
  • v-ssriganesh's avatar
    v-ssriganesh
    Hi E12345,
    Thank you for posting your query in the Microsoft Fabric Community Forum, and thanks to ralf_anton, KarinSzilagyi, tharunkumarRTK & Riny_vE for sharing valuable insights.
    Could you please confirm if your query has been resolved by the provided solutions? This would be helpful for other members who may encounter similar issues.
    Thank you for being part of the Microsoft Fabric Community.
  • dufoq3's avatar
    dufoq3
    Hi E12345, another solutions:
    Result:
    v1
        Source = Excel.CurrentWorkbook(),
        Range = Source{[Name="Range"]}[Content],
        Years = List.RemoveNulls(Record.ToList(Range{0})),
        Transformed = Table.Combine(List.Transform(Table.ToRows(Table.Skip(Range, 2)), each Table.FromRows(List.Transform(List.Zip({ Years, List.Split(_, 2) }), (x)=> {x{0}} & x{1}), type table[Year=Int64.Type, Course=text, Competitors=number])))
        Transformed
    v2
        Transposed = Table.FillDown(Table.FromColumns(Table.ToRows(Range)), {"Column1"}),
        RemovedColumns = Table.RemoveColumns(Transposed,{"Column2"}),
        UnpivotedOtherColumns = Table.UnpivotOtherColumns(RemovedColumns, {"Column1"}, "Attribute", "Competitions"),
        Ad_Course = Table.FillDown(Table.AddColumn(UnpivotedOtherColumns, "Course", each if Value.FromText([Competitions]) is text then [Competitions] else null, type text), {"Course"}),
        FilteredRows = Table.SelectRows(Ad_Course, each [Course] <> [Competitions] ),
        RemovedOtherColumns = Table.SelectColumns(FilteredRows,{"Column1", "Course", "Competitions"})
        RemovedOtherColumns
    v-ssriganesh
    Hello E12345,
    • E12345's avatar
      E12345
      Yes, the issue has been resolved – thank you to everyone who replied! I accepted one of the solutions because it provided a detailed step-by-step tutorial using GUI (graphical user interface) instead of just M code (I am not familiar with M code so it was hard for me to follow), but I plan to try the other ones as well to see how different approaches can lead to the same result. By the way, can I accept multiple solutions if they all work, or does it have to be just one? I'd like to give credit to everyone who helped. (Apologies for the delayed response – I’ve been swamped, but I’m still planning to test the other solutions too!)
