marccxx's avatar
marccxx
8 months ago
how to add duration using power query
Hi! I am new to Power BI and I need help for problem. I have a data that looks like this:
I want to make a column named Duration where it calculates the time for Title[A] and Title[B], or is there an easier way where I can use the duration for A and B when I use it in my report?
  • You can also use M code to calculate duration between A and B, no need for Duration column -> it can be added altogether via code
    Excel Data
    TitleTime
    A1:30 PM
    A1:35 PM
    A1:37 PM
    B12:30 PM
    B12:45 PM
    B12:46 PM
    Manual steps to perfomr -> Go to Power Query and set type data
    From the comment split A and B into separate tables is the code to create 2 tables, clean up data and calculate duration.
       // this is your source data from Excel
        Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content],
        // set correct data type
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"Time", type time}, {"Title", type text}}),
        // split A and B into separate tables
        table_a = Table.SelectRows(#"Changed Type", each [Title] = "A"),
        table_b = Table.SelectRows(#"Changed Type", each [Title] = "B"),
        // add Index column
        table_a_index = Table.AddIndexColumn(table_a, "Index", 0, 1, Int64.Type),
        table_b_index = Table.AddIndexColumn(table_b, "Index", 0, 1, Int64.Type),
        merge_ab = Table.NestedJoin(table_a_index, "Index", table_b_index, "Index", "b_table", JoinKind.Inner),
        expand_b = Table.ExpandTableColumn(merge_ab, "b_table", {"Time"}, {"b_time"}),
        // remove unnecessary columns and rename it
        rename_column_a = Table.RenameColumns(expand_b, {{"Time", "a_time"}}),
        remove_columns = Table.RemoveColumns(rename_column_a, {"Title", "Index"}),
        // calculate duration
        add_duration = Table.AddColumn(remove_columns, "Duration",
            each
                if [b_time] < [a_time] then [b_time] + #duration(1,0,0,0) - [a_time]
                else [b_time] - [a_time],
                type duration
        add_duration
    The outcome is the following
    If you find this helpful, Kudos are appreciated
    Excel Data
    TitleTime
    A1:30 PM
    A1:35 PM
    A1:37 PM
    B12:30 PM
    B12:45 PM
    B12:46 PM
        // add Index column
            each
                type duration
        add_duration
  • Please follow this process step by step you will get the desired result
    Power Query – Duration Calculation Between Item A and Item B
    This document explains how to calculate the time difference (Duration) between Item A and Item B using Power Query in Power BI.
    Scenario
    Item
    Time
    A
    1:30 PM
    A
    9:15 AM
    A
    3:45 PM
    B
    11:20 AM
    B
    2:10 PM
    B
    4:55 PM
    Solution Steps
    1. Open Power Query Editor in Power BI Desktop.
    2. Ensure the 'Time' column data type is set to Time.
    3. Add an Index Column (Add Column → Index Column → From 1).
    4. Duplicate the query and create two queries: A_Table and B_Table.
    5. Filter A_Table where Item = 'A' and B_Table where Item = 'B'.
    6. Merge A_Table with B_Table using the Index column (Left Join).
    7. Expand the Time column from B_Table.
    8. Add a Custom Column using the formula: [Time] - [B_Table.Time].
    9. Set the new column data type to Duration.
    Example Output
    Item
    Time (A)
    Time (B)
    Duration
    A
    1:30 PM
    11:20 AM
    02:10:00
    A
    9:15 AM
    2:10 PM
    -04:55:00
    A
    3:45 PM
    4:55 PM
    -01:10:00
    Git Hub File Reference, you can download that file with the solution.
    https://raw.githubusercontent.com/Murtaza-007-007/PBI-Fabric-Community/9d12a747d505383cd3cb43a65af225122772291e/Calculate%20Duration%20Using%20Power%20Query.pbix
    If this helped, ✓ Mark as Solution | Kudos appreciated
  • Hi marccxx ,
    When you refer that you want to calculate the duration is it the sum of the time between the current line and previous line so for this case second line 5 minutes third line 7 minutes?
    Or do you want to have a different way to calculate the duration?
    Depending on your needs there is the duration functions that allow you to do that calculation:
    https://learn.microsoft.com/en-us/powerquery-m/duration-functions
  • Hi Felix,
    leider wird nicht ganz klar was Du genau berechnen willst. Die Dauer zwischen den Vorgängerzeilen oder Indexabhängig zwischen A und B?
    Für den 1. Fall kannst Du so vorgehen:
    Für den 2. Fall wäre das möglich:
        Quelle = Excel.CurrentWorkbook(){[Name="Tabelle17"]}[Content],
        #"Geänderter Typ" = Table.TransformColumnTypes(Quelle,{{"Time", type time}}),
        #"Sortierte Zeilen" = Table.Sort(#"Geänderter Typ",{{"Time", Order.Ascending}}),
        Start = Table.SelectRows(#"Sortierte Zeilen", each ([Title] = "a")),
        #"Hinzugefügter Index" = Table.AddIndexColumn(Start, "Index", 0, 1, Int64.Type),
        Ende = Table.SelectRows(#"Sortierte Zeilen", each ([Title] = "b")),
        #"Hinzugefügter Index1" = Table.AddIndexColumn(Ende, "Index", 0, 1, Int64.Type),
        #"Zusammengeführte Abfragen" = Table.NestedJoin(#"Hinzugefügter Index", {"Index"}, #"Hinzugefügter Index1", {"Index"}, "Hinzugefügter Index1", JoinKind.LeftOuter),
        #"Erweiterte Hinzugefügter Index1" = Table.ExpandTableColumn(#"Zusammengeführte Abfragen", "Hinzugefügter Index1", {"Time"}, {"Ende_B"}),
        #"Entfernte Spalten" = Table.RemoveColumns(#"Erweiterte Hinzugefügter Index1",{"Index"}),
        #"Umbenannte Spalten" = Table.RenameColumns(#"Entfernte Spalten",{{"Time", "Start_A" }}),
        #"Hinzugefügte benutzerdefinierte Spalte" = Table.AddColumn(#"Umbenannte Spalten", "Dauer", each [Ende_B]-[Start_A], type duration)
    Hi marccxx ,
    I would also take a moment to thank Murtaza_Ghafoor  , for actively participating in the community forum and for the solutions you’ve been sharing in the community forum. Your contributions make a real difference.
    I wanted to check if you had the opportunity to review the information provided. Please feel free to contact us if you have any further questions
      Hi marccxx ,
      I hope the above details help you fix the issue. If you still have any questions or need more help, feel free to reach out. We’re always here to support you
  • Kateryna_dev's avatar
    Kateryna_dev
    Excel Data
    TitleTime
    A1:30 PM
    A1:35 PM
    A1:37 PM
    B12:30 PM
    B12:45 PM
    B12:46 PM
        // add Index column
            each
                type duration
        add_duration
    Kateryna_dev
    Excel Data
    TitleTime
    A1:30 PM
    A1:35 PM
    A1:37 PM
    B12:30 PM
    B12:45 PM
    B12:46 PM
        // add Index column
            each
                type duration
        add_duration
    Kateryna_dev
    Excel Data
    TitleTime
    A1:30 PM
    A1:35 PM
    A1:37 PM
    B12:30 PM
    B12:45 PM
    B12:46 PM
        // add Index column
            each
                type duration
        add_duration
