klehar's avatar
klehar
Icon for Helper V rankHelper V
5 years ago
Need help with my first custom function
I have created a custom function
I have started with just one column in the custom function but I will need many more columns related to a date input that I provide to the custom function
let DateTable = (DateInput as date) as table=>
    // Extract Fiscal Year Quarter from Start Date
    #"Inserted Start Date Year" = Table.AddColumn( "Year.1", each Date.Year([DateInput]),Int64.Type)
    DateTable
But when I try to invoke this I get the following error
What's wrong?
  • Hi klehar
    This step is to convert the original date value into a table. For table functions (like Table.RenameColumns, Table.TransformColumnTypes, Table.AddColumn...), the first argument should always be a table rather than other types.
    You could modify Pat's code into below and provide a specific date for Source step. In this way, it returns a table. You can add columns to it. After you have added all columns, remove "//" in the code and remove the Source=#date... step. Then it will be converted to a custom function again.
    // (DateInput as date) =>
    // Source = DateInput,
    Source = #date(2021,1,1),
    #"Converted to Table" = #table(1, {{Source}}),
    #"Renamed Columns" = Table.RenameColumns(#"Converted to Table",{{"Column1", "Date"}}),
    #"Changed Type" = Table.TransformColumnTypes(#"Renamed Columns",{{"Date", type date}}),
    #"Inserted Month Name" = Table.AddColumn(#"Changed Type", "Month Name", each Date.MonthName([Date]), type text),
    #"Inserted Year" = Table.AddColumn(#"Inserted Month Name", "Year", each Date.Year([Date]), Int64.Type)
    #"Inserted Year"
    You may find below articles helpful.
    Create Calendar Table Using Power Query M Language (mssqltips.com)
    Build a Reusable Calendar Table with Power Query - Excelerator BI
    Community Support Team _ Jing
  • Hi klehar ,
    Try putting a '#' in front of your table name in your Table.AddColumn function, like this:
    Table.AddColumn( #"Year.1", each Date.Year([DateInput]),Int64.Type)
    For what it's worth, I would strongly recommend naming tables and steps in Power Query with no spaces or special characters e.g. Year1 instead of Year.1, or insertedStartDateYear instead of Inserted Start Date Year etc.
    This makes it significantly easier to type out manual M code.
    Pete
  • mahoneypat's avatar
    mahoneypat
    There are a few things potentially wrong.  Along with the missing #, is Year.1 the name of an existing query?  Also, you are using your input parameter, which is a Date (not a table) inside [ ] which will make it look for a column named that.  What are you trying to accomplish with your function (input and desired output)?
    Pat
    • klehar's avatar
      klehar
      Hi Pat,
      My Input will be a date.
      Output will be a lot of columns like
      Month of date
      Day of date
      Year of date
      etc
        mahoneypat
        This is an example of a function like you describe.  I am curious how you plan to use it, as there may be a simpler way to accomplish your goal.
        Source = DateInput,
        #"Inserted Year"
        Pat
    It should be Table.AddColumn(#"Name of your Table", "Year.1", each etc
    --Nate
    Here's how you can fix your original query:
    (DateInput as date) as date =>
    Source = Table.FromValue(DateInput),
        #"Inserted Start Date Year" = Table.AddColumn(Source, "Year.1", each Date.Year([DateInput]),Int64.Type)
    --Nate
