Need help with my first custom function
- 5 years ago
Hi klehar
This step is to convert the original date value into a table. For table functions (like Table.RenameColumns, Table.TransformColumnTypes, Table.AddColumn...), the first argument should always be a table rather than other types.
You could modify Pat's code into below and provide a specific date for Source step. In this way, it returns a table. You can add columns to it. After you have added all columns, remove "//" in the code and remove the Source=#date... step. Then it will be converted to a custom function again.
// (DateInput as date) => let // Source = DateInput, Source = #date(2021,1,1), #"Converted to Table" = #table(1, {{Source}}), #"Renamed Columns" = Table.RenameColumns(#"Converted to Table",{{"Column1", "Date"}}), #"Changed Type" = Table.TransformColumnTypes(#"Renamed Columns",{{"Date", type date}}), #"Inserted Month Name" = Table.AddColumn(#"Changed Type", "Month Name", each Date.MonthName([Date]), type text), #"Inserted Year" = Table.AddColumn(#"Inserted Month Name", "Year", each Date.Year([Date]), Int64.Type) in #"Inserted Year"You may find below articles helpful.
Create Calendar Table Using Power Query M Language (mssqltips.com)
Build a Reusable Calendar Table with Power Query - Excelerator BI
Community Support Team _ Jing
It should be Table.AddColumn(#"Name of your Table", "Year.1", each etc
--Nate
