Need help with my first custom function
- 5 years ago
Hi klehar
This step is to convert the original date value into a table. For table functions (like Table.RenameColumns, Table.TransformColumnTypes, Table.AddColumn...), the first argument should always be a table rather than other types.
You could modify Pat's code into below and provide a specific date for Source step. In this way, it returns a table. You can add columns to it. After you have added all columns, remove "//" in the code and remove the Source=#date... step. Then it will be converted to a custom function again.
// (DateInput as date) => let // Source = DateInput, Source = #date(2021,1,1), #"Converted to Table" = #table(1, {{Source}}), #"Renamed Columns" = Table.RenameColumns(#"Converted to Table",{{"Column1", "Date"}}), #"Changed Type" = Table.TransformColumnTypes(#"Renamed Columns",{{"Date", type date}}), #"Inserted Month Name" = Table.AddColumn(#"Changed Type", "Month Name", each Date.MonthName([Date]), type text), #"Inserted Year" = Table.AddColumn(#"Inserted Month Name", "Year", each Date.Year([Date]), Int64.Type) in #"Inserted Year"You may find below articles helpful.
Create Calendar Table Using Power Query M Language (mssqltips.com)
Build a Reusable Calendar Table with Power Query - Excelerator BI
Community Support Team _ Jing
Hi klehar ,
Try putting a '#' in front of your table name in your Table.AddColumn function, like this:
Table.AddColumn( #"Year.1", each Date.Year([DateInput]),Int64.Type)
For what it's worth, I would strongly recommend naming tables and steps in Power Query with no spaces or special characters e.g. Year1 instead of Year.1, or insertedStartDateYear instead of Inserted Start Date Year etc.
This makes it significantly easier to type out manual M code.
Pete
