Maltaparis's avatar
Maltaparis
1 year ago
Need help to fix my code
Dear all,
I need your help
I am getting crazy, in Powerquery, I created a calculated column but it doesnt worK
All the column names are correct
It keep stating there is a syntax error with "and" or with the column DATE if I dont use ([Date]) bur rather [Date]
Date is also in a date format
Can someo,ne help me?
Thank u all fr you help
if ([Date] = [DateMin] and
    Table.RowCount(Table.SelectRows(MS, each [MAT] = [MAT] and [Date] = [DateMax])) > 0) then "Présent"
else if ([Date] = [DateMax] and
         Table.RowCount(Table.SelectRows(MS, each [MAT] = [MAT] and [Date] = [DateMin])) = 0) then "Nouveau"
else if ([Date] <> [DateMax] and
         Table.RowCount(Table.SelectRows(MS, each [MAT] = [MAT] and [Date] = [DateMax])) = 0) then "Départ"
else "Autre"
  • There is no need for parentheses here after if .
    But you are missing the reference to the outer scope.
    each [MAT] = [MAT]
    will always evaluate to true and
    doesn't know where to find [Date].
    Show the entire code for that step if you want further help.
    each [MAT] = [MAT]
  • The problem is related to each _ syntax. when you add a new column it will automaticly add each at the begining of the third argument (place you write the formula,) so in your formula you can not use each _ again becuse the variables (_)  will be ,mixed, so replace each _ by new variable name like (x)=> and rewrite the formula as below
        Table.RowCount(Table.SelectRows(MS, (x)=> x[MAT] = _[MAT] and x[Date] = _[DateMax])) > 0) then "Présent"
             Table.RowCount(Table.SelectRows(MS, (x)=> x[MAT] = _[MAT] and x[Date] = _[DateMin])) = 0) then "Nouveau"
             Table.RowCount(Table.SelectRows(MS, (x)=> x[MAT] = _[MAT] and x[Date] = _[DateMax])) = 0) then "Départ"
    else "Autre"
  • The reason for the error is that [Date] in Table.SelectRows does not exist in the MS table.
    There is also a semantic error where the expression "[MAT] = [MAT]" is always true.
    Take some of them as examples (please modify according to the actual content):
    //Table.RowCount(Table.SelectRows(MS, each [MAT] = [MAT] and [Date] = [DateMax]))
    Table.RowCount(Table.SelectRows(MS, (r) => x[MAT] = [MAT] and x[Date] = [DateMax]))
    A prefix with "r" indicates that it is from an MS table, and a prefix with no "r" indicates that it is from an external table (a table to which columns are added).
  • Maltaparis's avatar
    Maltaparis
    Dear all,
    First of all thank you very much for your heklp
    To answer some of the question
    My code is complete
    I have so far a ingle Table called 'MS", with a column Date (in date format), I dont understand why the code is acting like it doesnt exist?
    • lbendlin's avatar
      lbendlin
      My code is complete
      If that were the case you wouldn't have the errors.
      That's not the problem.  You need to reference the individual steps in your process, and you need to take special care of nested scopes.
      I have so far a single Table called 'MS"
      That's the name of the final output.  Each applied step has a different name.
      Please show the entire code.
      HI Maltaparis ,
      I noticed that 'MS' appears in the first parameter of Table.SelectedRows.
      Bof
    Maltaparis
    I also Add, MS is the name I gve to my table ,
