Maltaparis
1 year agoFrequent Visitor
Need help to fix my code
Dear all, I need your help I am getting crazy, in Powerquery, I created a calculated column but it doesnt worK All the column names are correct It keep stating there is a syntax error with "and" ...
- 1 year ago
There is no need for parentheses here after if .
But you are missing the reference to the outer scope.
each [MAT] = [MAT]will always evaluate to true and
and [Date] = [DateMax]doesn't know where to find [Date].
Show the entire code for that step if you want further help.
Omid_Motamedise
1 year agoThe problem is related to each _ syntax. when you add a new column it will automaticly add each at the begining of the third argument (place you write the formula,) so in your formula you can not use each _ again becuse the variables (_) will be ,mixed, so replace each _ by new variable name like (x)=> and rewrite the formula as below
if ([Date] = [DateMin] and
Table.RowCount(Table.SelectRows(MS, (x)=> x[MAT] = _[MAT] and x[Date] = _[DateMax])) > 0) then "Présent"
else if ([Date] = [DateMax] and
Table.RowCount(Table.SelectRows(MS, (x)=> x[MAT] = _[MAT] and x[Date] = _[DateMin])) = 0) then "Nouveau"
else if ([Date] <> [DateMax] and
Table.RowCount(Table.SelectRows(MS, (x)=> x[MAT] = _[MAT] and x[Date] = _[DateMax])) = 0) then "Départ"
else "Autre"
