Need help to fix my code
- 1 year ago
There is no need for parentheses here after if .
But you are missing the reference to the outer scope.
each [MAT] = [MAT]will always evaluate to true and
and [Date] = [DateMax]doesn't know where to find [Date].
Show the entire code for that step if you want further help.
Dear all,
First of all thank you very much for your heklp
To answer some of the question
My code is complete
I have so far a ingle Table called 'MS", with a column Date (in date format), I dont understand why the code is acting like it doesnt exist?
- lbendlin1 year ago
My code is completeIf that were the case you wouldn't have the errors.
I dont understand why the code is acting like it doesnt exist?That's not the problem. You need to reference the individual steps in your process, and you need to take special care of nested scopes.
I have so far a single Table called 'MS"That's the name of the final output. Each applied step has a different name.
Please show the entire code.
- Anonymous1 year agoNot applicable
HI Maltaparis ,
I noticed that 'MS' appears in the first parameter of Table.SelectedRows.
Bof
