Anonymous's avatar
4 years ago
Running total problems
Having some issue with running total. Can anyone suggest solution for this?
I have tried something like this, but I get the same result as in totals[total_count] column:
running sum = CALCULATE(totals[total_count], FILTER(stages, stages[created_at] <= MAX(stages[created_at])))
Also in report I dont use any date fields.
  • Anonymous , The data you have show stage is sortable, you can use
    running sum = CALCULATE(totals[total_count], FILTER(stages, stages[stage] <= MAX(stages[stage])))
    Or Create a stage no column
    stages no = right([Stage], len([Stage]) -5)
    and then try
    running sum = CALCULATE(totals[total_count], FILTER(stages, stages[stage no] <= MAX(stages[stage no])))
    and then try
      amitchandak Thank you. Solution with stage no (index) works!
  • amitchandak I think your measure needs a fix, need ALL
    running sum = CALCULATE(totals[total_count], FILTER(ALL(stages), stages[stage] <= MAX(stages[stage])))
    ✨ Follow us on LinkedIn and  to our YouTube channel
    I would ❤ Kudos if my solution helped. 👉 If you can spend time posting the question, you can also make effort to give Kudos to whoever helped to solve your problem. It is a token of appreciation!
    ⚡ Visit us at https://perytus.com, your one-stop shop for Power BI-related projects/training/consultancy.
