Anonymous's avatar
4 years ago
Running total problems
Hi,  Having some issue with running total. Can anyone suggest solution for this? I have tried something like this, but I get the same result as in totals[total_count] column: running sum = CALCUL...
  • amitchandak's avatar
    4 years ago
    Anonymous , The data you have show stage is sortable, you can use
    running sum = CALCULATE(totals[total_count], FILTER(stages, stages[stage] <= MAX(stages[stage])))
    Or Create a stage no column
    stages no = right([Stage], len([Stage]) -5)
    and then try
    running sum = CALCULATE(totals[total_count], FILTER(stages, stages[stage no] <= MAX(stages[stage no])))
