4 years agoNot applicable
Running total problems
Hi, Having some issue with running total. Can anyone suggest solution for this? I have tried something like this, but I get the same result as in totals[total_count] column: running sum = CALCUL...
- 4 years ago
Anonymous , The data you have show stage is sortable, you can use
running sum = CALCULATE(totals[total_count], FILTER(stages, stages[stage] <= MAX(stages[stage])))
Or Create a stage no column
stages no = right([Stage], len([Stage]) -5)
and then try
running sum = CALCULATE(totals[total_count], FILTER(stages, stages[stage no] <= MAX(stages[stage no])))
parry2k
4 years agoamitchandak I think your measure needs a fix, need ALL
running sum = CALCULATE(totals[total_count], FILTER(ALL(stages), stages[stage] <= MAX(stages[stage])))
✨ Follow us on LinkedIn and to our YouTube channel
I would ❤ Kudos if my solution helped. 👉 If you can spend time posting the question, you can also make effort to give Kudos to whoever helped to solve your problem. It is a token of appreciation!
⚡ Visit us at https://perytus.com, your one-stop shop for Power BI-related projects/training/consultancy.
