mahajan
7 years agoFrequent Visitor
Pyhton script problem in Power BI.
Hi I have a table already imported in Power BI Desktop with
A B
'14' '10'
'12' null
I was trying to transform that using Python Script in power BI. I was trying to use the Dataframe.fillna(value) function in the script that works fine and apparently changes the all the null in the table to the value.
But when I try to change the null value only in one of the column ( in this case in the column 'B') the python script returns me the same dataset. For example, this is the code I am trying to run
# 'dataset' holds the input data for this script
import pandas as pd
final = dataset['B'].fillna('0')above script gives me back the dataset, not the transformed final one as I expected.
1 Reply
- v-chuncz-msft
