fbostan1's avatar
fbostan1
4 years ago
power query IF statement help
how to write a formula in powerbi for "if a column from my current table equals to a column in another table then its xxx if not xxx"?
I can't do conditional column becase the two columns are in two different tables.
I'm trying to use the custom column to do this.
Any help would be appreacited
thanks!
    4 years ago
    Hi fbostan1 ,
    My Sample is as below.
    Table1:
    Table2:
    Custom column:
    if List.Contains(Table2[Column1],[Column1]) = true then "Y" else "N"
    Result is as below.
    Rico Zhou
  • fbostan1 well, you have to merge these two tables together on a common key, expand the column you need from the 2nd table, and then write the if condition and remove the unwanted columns.
    ✨ Follow us on LinkedIn and  to our YouTube channel
    I would ❤ Kudos if my solution helped. 👉 If you can spend time posting the question, you can also make efforts to give Kudos to whoever helped to solve your problem. It is a token of appreciation!
    ⚡ Visit us at https://perytus.com, your one-stop shop for Power BI-related projects/training/consultancy.
    • fbostan1's avatar
      fbostan1
      I can't figure out how to merge this two column from two different table into one column.
      • Ashish_Mathur's avatar
        Ashish_Mathur
        You can merge 2 tables on the basis of at least 1 common column between 2 tables.
  • fbostan1 it will be easier if you put a sample data of both tables in excel sheet and the expected output, and share it using one drive/google drive and try to put something together for you.
    Hi fbostan1 ,
    Table1:
    Table2:
    Custom column:
    Result is as below.
    Rico Zhou
