fbostan1
4 years agopower query IF statement help
how to write a formula in powerbi for "if a column from my current table equals to a column in another table then its xxx if not xxx"? I can't do conditional column becase the two columns are in two...
- Anonymous4 years ago
Hi fbostan1 ,
My Sample is as below.
Table1:
Table2:
Custom column:
if List.Contains(Table2[Column1],[Column1]) = true then "Y" else "N"Result is as below.
Rico ZhouIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
4 years agoNot applicable
Hi fbostan1 ,
Table1:
Table2:
Custom column:
Result is as below.
Rico Zhou
