fbostan1
4 years agopower query IF statement help
how to write a formula in powerbi for "if a column from my current table equals to a column in another table then its xxx if not xxx"? I can't do conditional column becase the two columns are in two...
- Anonymous4 years ago
Hi fbostan1 ,
My Sample is as below.
Table1:
Table2:
Custom column:
if List.Contains(Table2[Column1],[Column1]) = true then "Y" else "N"Result is as below.
Rico ZhouIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
parry2k
4 years agofbostan1 it will be easier if you put a sample data of both tables in excel sheet and the expected output, and share it using one drive/google drive and try to put something together for you.
✨ Follow us on LinkedIn and to our YouTube channel
I would ❤ Kudos if my solution helped. 👉 If you can spend time posting the question, you can also make efforts to give Kudos to whoever helped to solve your problem. It is a token of appreciation!
⚡ Visit us at https://perytus.com, your one-stop shop for Power BI-related projects/training/consultancy.
