Anonymous's avatar
4 years ago
Need help with Conditional Formatting based on dynamic threshold values
PBI SAMPLE FILE ATTACHED
I have visual 1 and visual 2.  When I select a country in Visual 1, Visual 2 shows data for that country.
I want  a conditional formatting in Visual 2 to highlight ‘Subjects’ Or ‘Average of Marks’ where ‘Average Of Marks’ is below PassingGrade for that Country.
For example If I select Japan in Visual 1, Math and Physics in Visual 2 should get highlighted on the basis of ‘Threshold for Reference’ table
But If I select Singapore in visual 1 , Physics should get highlighted on the basis of ‘Threshold for Reference’ table
      Big thanks, this works!!
      Is there a way to highlight them with Red flags like below instead of background color?
      If you could share the file or code snippet to do that would be great!
      • Jihwan_Kim's avatar
        Jihwan_Kim
        Thank you for your feedback.
        I amended the measure, and now it show a flag based on the condition.
        Please check the attached file if it suits your requirement.
    I made a measure to use for conditional formatting called "test" :
    I hope that solved the issue 🙂
    Hi, Can you share the power Bi file?
    Did you join the Passing Score and Sheet 2 tables? Will this work dynamicaly if I selecting different countries in Visual 1
      Yes, I did join the two tables on Country. And it will work dynamically.
        Hi , I tried replicating your approach as it is simplete but it is not working correcly, Check below for instance. THis should have highlighted Math as well? I think Test measure need to be tweaked a little bit. You are using Sum, and not average there, why?
