4 years agoNot applicable
Need help with Conditional Formatting based on dynamic threshold values
PBI SAMPLE FILE ATTACHED I have visual 1 and visual 2. When I select a country in Visual 1, Visual 2 shows data for that country. I want a conditional formatting in Visual 2 to highlight ‘Subjec...
- 4 years ago
Please check the attached file.
Jihwan_Kim
4 years agoHi,
Big thanks, this works!!
Is there a way to highlight them with Red flags like below instead of background color?
If you could share the file or code snippet to do that would be great!
- Jihwan_Kim4 years ago
Thank you for your feedback.
I amended the measure, and now it show a flag based on the condition.
Please check the attached file if it suits your requirement.
I wrote a bit more detail about explaining how the measure works in the link down below.
