4 years agoNot applicable
Need help with Conditional Formatting based on dynamic threshold values
PBI SAMPLE FILE ATTACHED I have visual 1 and visual 2. When I select a country in Visual 1, Visual 2 shows data for that country. I want a conditional formatting in Visual 2 to highlight ‘Subjec...
- 4 years ago
Please check the attached file.
I made a measure to use for conditional formatting called "test" :
I hope that solved the issue 🙂
