Need help - Column difference in a matrix
Good afternoon all!
I'm in dire need of some help.
I have the following matrix making use of 3 fields:
- Description
- Period
- Cost
My issue is the following, i want to add a column next to the 2 dates which does a value of 202002 - value of 202001
i want it to only to the difference based on the 2 periods i selected in the filter visual.
Any help would be appreciated or guidance on how to do it better.
Regards
Hi Anonymous
Create measures
Measure 2 = VAR m1 = MINX ( ALLSELECTED ( 'Table 2' ), [period] ) VAR m2 = MAXX ( ALLSELECTED ( 'Table 2' ), [period] ) RETURN CALCULATE ( SUM ( 'Table 2'[cost] ), FILTER ( 'Table 2', 'Table 2'[period] = m2 ) ) - CALCULATE ( SUM ( 'Table 2'[cost] ), FILTER ( 'Table 2', 'Table 2'[period] = m1 ) ) Measure = IF(ISINSCOPE('Table 2'[period]),SUM('Table 2'[cost]),[Measure 2])Best Regards
Maggie
- v-juanli-msftCommunity Support
Hi Anonymous
Create measures
Maggie
If this post helps, then please consider Accept it as the solution to help the other members find it more quickly.- AnonymousNot applicable
thank you very much! Works like a charm!
thanks to everyone else who also gave inputs and solutions.
appreciate it!
- amitchandakSuper User
Make sure period are in a separate table for better working
Measure =
var _min = minx(Period,Period[Name])
var _max = maxx(Period,Period[Name])
return
calculate(sum(table[cost]),filter(all(Period),Period[Name]=_min)) -calculate(sum(table[cost]),filter(all(Period),Period[Name]=_max))if you need more help make me @
Appreciate your Kudos.- AnonymousNot applicable
thanks amitchandak , i tried this and didnt give any errors, but it doesnt want to do the calculation. It just returns a 0.
Can you share sample data and sample output.
- NishantjainContinued Contributor
Below is a suggestion
Create 3 measures
Measure 1
Previous Period = VAR mindate = min(period) return Calculate(Sum(Data[values]), Period[period] = mindate)Measure 2:
Latest period= VAR maxdate = max(period) return Calculate(Sum(Data[values]), Period[period] = maxdate)Measure 3:
Variance = [Measure 1] - [Measure 2]Drop each of these measures in your matrix and remove the period field from the matrix
Few things to note:
1. If you select more than 3 period, it will automatically default to 2 period selecting the minimum and maximum date
2. The column headers will not show the period name, but would show the name of the measure
